Which drive shaft?
Old Jun 22, 2018 | 02:12 PM
meck1's Avatar
meck1
Which drive shaft?
I've got a '94 extended cab, 2wd, with the driveshaft that has the center support bearing. I'm replacing the drive shaft and have two that I can use. One is the normal shaft with single u-joints. The other has a cardan joint by the center support bearing. Is there an advantage of one of these driveshafts over the other? The truck is not lifted. Any advice will be appreciated. Thanks.
Old Jun 23, 2018 | 08:48 PM
wtroger's Avatar
wtroger
The Cardan can handle more drive shaft angle.
Old Jun 25, 2018 | 08:57 AM
meck1's Avatar
meck1
Thank you,
neelsnoles
2009 - 2014 F150
Jan 17, 2019 07:49 AM
postalxj
Dec 19, 2009 01:10 PM
judi48
Jan 12, 2008 12:21 PM
busakiller2001
Nov 9, 2007 12:43 PM
