Key switch?
Old Oct 3, 2003 | 04:01 PM
  #31
rebelbrowser's Avatar
rebelbrowser
who posted their address, me ?
Old Oct 4, 2003 | 07:24 AM
  #32
opi8's Avatar
opi8
Tkcollin,
No I am still struggling through this thing, I got you link thanks!!
But I cannot seem to find which section the diagram i need is in. Is it in "steering/suspension" then "keylock cylender"??
This manual will lhelp me tremendously, I just need to know where exactly to look.
Could you let me know when you get some time?
Thanks again!!
Opi
Old Oct 6, 2003 | 08:51 PM
  #33
tkcollin's Avatar
tkcollin
Opie8, The link you need is under -Steering & Suspension - Steering - Ignition switch - Then it is figure 4 and figure 5 and the narritive at the bottom. The part that is probably broke is the upper ignition actuator (it is shown in dashed lines in figure 5). You will have to buy a steering wheel puller, pull the steering wheel, and remove the turn signal switch which can be fun since the wires are just long enough to permit it to be pulled off the end of the steering shaft. After this you should be able to see the upper actuator linkage. It will also help to remove the shroud round the bottom of the column. Once you try this give me a yell. Try e-mailing me (I think I set my profile up to allow it).
I tried e-mailing you but your profile won't permit it.
Old Oct 7, 2003 | 10:43 AM
  #34
opi8's Avatar
opi8
TKcollin,
Ok, I have basically the whole colum ripped apart, the piece that is broken slides down inside the colum itself. Problem is that it is way to long to remove.
So what I did was remove the 3 allen head screws that holds the casting on but I still cannot slide that thing over the shaft where the steering wheel slides on (the snap ring is removed). It almost looks like a "knuckle is stopping it from coming off. Do I have to remove that whole knuckle assembly as well?
I would E-Mail you but I havent been a member long enough to do so.
Thanks again for all you time.
Old Oct 7, 2003 | 10:52 AM
  #35
opi8's Avatar
opi8
Tkcollin,
Also, what is the exact name of that part so I can buy a replacemrnt. I have looked on Napaonline.com but have had no luck.
Thanks,
Opi8
Old Oct 7, 2003 | 12:35 PM
  #36
tkcollin's Avatar
tkcollin
Opie,
The part that was broke on mine was the upper ignition rod actuator. It is made out of white metal (pot metal) and is about 4 to 5 inches long and has a "C" shaped foot on the end facing the steering wheel. Is this what is broke on yours? where is it broke? There is a little pin at the end of the C shaped foot and that connects to the geared rod that is worked by the key cylinder. Make sure that this pin is not broken. Mine broke where the C shaped foot attaches to the rod.
If it is the upper actuator, you will need to take the snap ring off and loosen the allen head bolts (sounds like you did this). I was able to pull up on the casting and move it and the upper bearing up the shaft enough so that I could tilt the steering wheel all the way down (mine is a tilt is yours?) and fit the part in. I had to pull up on the casting until the knuckle stopped me, then tilt all the way down.
Any way you can take a picture and post it?
Old Oct 7, 2003 | 04:00 PM
  #37
opi8's Avatar
opi8
Where do I buy?
Hi again TK,
Good news!!! I got it out!!!
Now is there a specific place I need to buy this item from?? Or is it a special order through Ford? Ive been looking on the online stores but cannot find it.
Could you let me know where you got yours from?
Thaks
Opi
Old Oct 7, 2003 | 07:26 PM
  #38
tkcollin's Avatar
tkcollin
Opi8 (sorry about the added "e" in previous posts, apparently I'm not to detail oriented). You will have to get this part from the ford dealer, when I got mine, the guy said they give them out in 10's and 20's (meaning that they are a common problem). Was it the upper actuator? When you put it back in, there is a trick to lining up the cylinder lock gear with the actuator rod so that the key lock turns to the right position (see the directions on the Chilton website).
Let me know how it turns out.
Old Oct 13, 2003 | 06:03 PM
  #39
opi8's Avatar
opi8
I DID IT!!!!
Hi TK,
I just wanted to let you know that the issue I had is resolved!!
Everything works fine!!! I couldnt have done it without your help!!
Thanks ALOT!!!
Opi
Old Oct 13, 2003 | 06:21 PM
  #40
Thudpucker's Avatar
Thudpucker
Greywolf, I havent any idea what a Web BOT might be. But you said that once before and I took heed! But what is it?
Old Oct 14, 2003 | 06:44 AM
  #41
tkcollin's Avatar
tkcollin
Opi,
Good stuff! Next time you see someone asking about an ignition switch on the forum give 'em a yell, you are the expert now!
Old Jul 16, 2004 | 11:34 AM
  #42
1990F250_firstimer's Avatar
1990F250_firstimer
Worn Ignition/key switch woes
I've got the same problem of a very loose upper ignition rod/actuator connection that dosn't put any pressure on the ignition switch. Not sure how much I would have to take this steering apart to get there but it sounds like complete disassembly. I've got the steering coumn laying down on the seat and the ignition switch itself out and it appears fine. My question... anyone have pictures of getting to the worn parts next to the ignition key that pushes and pulls this control rod? I've tried to follow the links but they don't take me to any pictures. Lot's of thanks in advance. This is a great site for information on these machines. - Dwayne from Florida
Old Jul 16, 2004 | 04:24 PM
  #43
Thudpucker's Avatar
Thudpucker
Dewayne, you might do a search and see one of those photo's. Some guys on this forum have wonderful rescources.
But it's sefl explanatory. Go by the part from AutoZone or other supplier.
When you have the part in hand, you'll be comfortable with the next step.
God Bless you Henry Ford. May your engineers forced to sleep with Bin Laudens 72 virgins.
In Seattle right now.
Old Jul 19, 2004 | 06:25 AM
  #44
1990F250_firstimer
Lost my nerve... found the ignition switch itself in good condition. Lubricated it and readjusted so that "RUN" position and "OFF" works well. Ran a seperate "START" push button which places +12VDC on the starter relay coil to keep from having to place pressure on this spring position. I'm happy - it's an old truck with lots of life in the running gear.
Old Aug 29, 2004 | 10:22 PM
  #45
DustyDogBM03's Avatar
DustyDogBM03
Lock cylinder...Key switch
Originally Posted by rebelbrowser
I dont understand what is happening, when i post i get extra text like html code apearing within the intended text.
There is no hole near the key switch where the pin gets pushed in on this unit.
I am stumpped. How do I remove The cylinder if i can not find the hole. I own a 1991 Explorer with a tilt wheel.
Thx 4 The help
Dusty
