Key switch?
Old Sep 29, 2003 | 04:02 PM
rebelbrowser's Avatar
rebelbrowser
i just ordered a new NON tilt replacement from my local yard for 150 bucks site un seen. I hope it matchs my decore.
Old Sep 30, 2003 | 10:19 AM
rebelbrowser
I took it apart and put it back togeher w/o the cylinder, now i can start it by pushing the rod forward. I feel the "detent" when i do that. Why is my tilt so loose?
Old Sep 30, 2003 | 11:46 AM
stepman's Avatar
stepman
Isuspect that you pivot bushings are worn and I know of no cure for that.
Old Sep 30, 2003 | 07:45 PM
opi8's Avatar
opi8
Question potmetal link
Thudpucker,
How do i inspect or replace that rod? The ignition switch works, but it seems that the rod isnt giving enough uuupmph to push the switch to the start position.
Is there anywhere there is a diagram available to find an easy way to that rod and what its supposed to look like if I even do find it?
I'm dead in the water here, and again, thanks for all help!!
Opi
Old Sep 30, 2003 | 07:55 PM
stepman's Avatar
stepman
If you mean that you have to turn the switch a loooong ways before it cranks than that should be adjustable at the switch. If you have a decent library nearby you may be able to go down there and look in the referance section for Mitchell Manuals. These are a lot more helpful than the ones that you can buy at the parts store. More diagnostics and better pics in them.
Old Sep 30, 2003 | 09:11 PM
rebelbrowser
Mitchell Manuals, huh ,hmmmm.Thanks for posting !
I guess youd have to drop the column down to really get to that switch.I get a new non tilt tomorrow. will see if it has the switch and whats what . Turns out i think its the RUN position the key slides out in.I didnt find 1985 info at the library.I saw big sections for chilton/haynes but all were 2001+.Nothing for a great looking P.O.S. like my truck.
Old Sep 30, 2003 | 09:18 PM
stepman's Avatar
stepman
Yeah, great manuals. Normally, you can't check them out but, you can copy pages. Not all libraries carry them though.
Old Oct 2, 2003 | 10:29 AM
rebelbrowser
Old Oct 2, 2003 | 10:44 AM
rebelbrowser
I dont understand what is happening, when i post i get extra text like html code apearing within the intended text.
There is no hole near the key switch where the pin gets pushed in on this unit.
Old Oct 2, 2003 | 10:48 AM
stepman's Avatar
stepman
I don't know what happened there but, when I opened this thread I got a couple of link looking things and a message about the pin hole then when I came back I got pics but no message. On this column, I believe that you have to remove the wheel and the turn signal switch. Under that you'll see a small screw that holds the switch in. Or it may have a slot with the "key" to push. Either way , it's inside.
Old Oct 2, 2003 | 05:44 PM
rebelbrowser
the new column is in and works well. No horn till i changed the steering wheel cover with mine that has a ground wire and cruise control buttons. can anyone say wether my cruise buttons should work here now ? It didnt work before. However, I did spot extra springs on the throttle linkage under the hood. The wiring looks the same as before.There were only two leads and a ground.
Old Oct 2, 2003 | 06:14 PM
stepman's Avatar
stepman
I'm no good at cruise but glad to hear you got it going again. Long road, huh? Now you should be an expert.
Old Oct 2, 2003 | 08:59 PM
  #28
tkcollin's Avatar
tkcollin
Opie8 did you get you problem fixed? The same thing happend to me, it was not the lock cylinder but the upper rod actuator, which attaches to the ignition rod. It is a bit of work to take apart but not to difficult. To talk you through it you should have a diagram of the column (otherwise the terminology gets to tedious) I have a diagram of it but can't seem to get it to post to the message board, send me your emailand I will send you the diagram of the column and ignition switch and we can work from there.
Try this link http://www.cybrrpartspro.com/cgi-win...kupResults***** for a steering column diagram
Old Oct 2, 2003 | 09:01 PM
  #29
tkcollin's Avatar
tkcollin
Oops, looks like that last link did not work, lets try this again
Old Oct 2, 2003 | 10:04 PM
  #30
Greywolf's Avatar
Greywolf
WAIT WHOA STOP!
NEVER post an E-Mail address on FTE, there are web BOT's out there that specifically search for e-maill addresses online. Once they find one, they continue to seek around the website they were on until they have searched everywhere...
This is why we've been seeing a lot of "SERVER BUSY, TRY AGAIN" messages when coming here, Ken filled all of the mods in on it a while ago.
If you check a users profile, you can find a link that allows the site to forward an e-mail to that user, but out-front addresses are a no no...
~Wolfuss
