Timing set
Old Jun 21, 2018 | 09:37 PM
TXTrailerdaddy's Avatar
TXTrailerdaddy
Timing set
I bought an edelbrock timing set for the 460. It's got 3 keyways 4 degrees advance, 0 degrees and 4 degrees retarded. What it doesnt have is the dot on the dot on the crank gear. Any guidance on how to set this up properly?The instructions show the crank gear with a dot on the tooth like the cam gear has.
Old Jul 11, 2018 | 10:14 PM
wtroger's Avatar
wtroger
Key on crank at 12 o’clock. You really need to degree it in to determine where to set it. If not use the 0 slot. I had to use the 4 degree advanced slot on the last 351 I built just to get to zero. It was retarded right at 4 degrees when the 0 slot was used.
SoCalExile
May 8, 2010 11:02 AM
Crabby144
Apr 6, 2010 06:52 AM
7salinas3
21
Jan 14, 2008 09:26 PM
shep89
Jun 5, 2003 01:21 PM
