2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Power steering noise... please HELP!
Old 06-21-2018, 08:01 PM
Odyssey350kc's Avatar
Odyssey350kc
Odyssey350kc is offline
Watch video with sound
Took my truck to the dealership. They ended up changing out the power steering pump. Got it back today and took the video when i got home. So needless to say i'm a bit irritated. Did a bit of research to find plenty of people having the problem with no solutions. If I knew this would happen I never would have bought the truck. It drives me absolutely crazy. If anyone has had this problem and found any solution I would love to know
Old 06-21-2018, 09:29 PM
screwy's Avatar
screwy
screwy is offline
Sounds like the gearbox to me.
Old 06-21-2018, 09:38 PM
briangp's Avatar
briangp
briangp is offline
To me sounds like there is air in the system. Maybe they didn't fill the gearbox all the way?
Old 06-21-2018, 10:28 PM
Vinford's Avatar
Vinford
Vinford is offline
Took mine in for this today , they told me nothing was wrong with it they all made that noise.
I call bs on that but at least its documented.
Old 06-21-2018, 10:42 PM
stangman68inftc's Avatar
stangman68inftc
stangman68inftc is offline
So I can't help but this sounds like the noise my truck makes at full lock either direction and has from day 1. I've been meaning to take it to the dealership to see if I should be worried about it. Maybe someone else with some knowledge of the situation will chime in.
Old 06-21-2018, 11:30 PM
Jimmycat1's Avatar
Jimmycat1
Jimmycat1 is offline
Power steering.
Mine also makes a similar sound. Mine sounds as if it’s sending feedback through the center channel speaker. I’m going to have dealer look at it when it goes in for the first oil change.
Old 06-22-2018, 07:45 AM
C12H24's Avatar
C12H24
C12H24 is offline
It sounds like aerated fluid. Does it make the noise on morning first start or does it have to run a bit before it starts? You can get fluid aeration when you replace hydraulic components and it can take some time for all the bubbles to work their way out of the fluid. You can also get persistent aeration when the front seal on the pump is pulling air. The seal can be fluid-tight, but not air tight. You can also get bubbles in the system from low fluid level. It can be solved and it may do so on its own, but the shop's response that they all do it is pure nonsense.
Old 06-22-2018, 11:49 AM
Tricon's Avatar
Tricon
Tricon is offline
Mine does this at full lock, always has. Everyone has always said its normal.
Old 06-22-2018, 01:46 PM
No.15's Avatar
No.15
No.15 is offline
Mine makes noise as well. Only at full lock and it sounds like it comes from just below the steering wheel. I think mine is the ps assist and it has done it from day one
Old 06-22-2018, 01:51 PM
Tricon's Avatar
Tricon
Tricon is offline
Are you talking about adaptive steering? It's definitely not that, because I don't have that.
Old 06-22-2018, 01:57 PM
No.15's Avatar
No.15
No.15 is offline
yeah I think mine is the adaptive steering. That's why I pointed out the location of the sound in case it was different from the op . I could not tell from the video because it's noisy here
Old 06-22-2018, 02:00 PM
Tricon's Avatar
Tricon
Tricon is offline
That's what I'm saying, I get that squirting fluid noise in my steering wheel as well and I do not have adaptive steering, so it's not that.
Old 06-22-2018, 02:22 PM
stangman68inftc
Don't think I have adaptive steering either on my XL STX.
Old 06-22-2018, 06:43 PM
Odyssey350kc
It wouldn't bother me if it were just at full cut but it does it at almost any position. And I checked to make sure it was full of power steering fluid before i brought it into the dealer. Strangely enough i haven't been able to get it to make the noise today except at full lock - which i know not to hold. So hopefully it was just some air in the line after replacement and the new pump fixed it, but i doubt it.
Old 06-22-2018, 07:36 PM
mrgrayaz's Avatar
mrgrayaz
mrgrayaz is offline
I have never met a Ford with a quiet power steering pump.
It's embarrassing really....
Quick Reply: Power steering noise... please HELP!
