Ignition Switch problems.
Old Jun 21, 2018 | 12:50 PM
Jack Sengstaken's Avatar
Jack Sengstaken
Hey guys. Been having some trouble with my 84 f150. Truck starts fine but the heater, and blinkers dont work unless I rotate and hold the key forwards towards the start position. Is this the cylinder or the switch. I dont really know what part to order and I dont want to take it apart until I know what is up because I use this truck as my daily driver. Than you!
Old Jun 22, 2018 | 06:33 AM
FuzzFace2's Avatar
FuzzFace2
Before you order anything you can try and adjusting the switch.
It is bolted to the steering column with 2 screws, think 5/16" heads.
The switch has slots and can be moved. I cant remember now just how its done but you can try a little movement and test.
If not good go the other way and test again.
I would say the easiest to replace is the switch if you were going to do either.
Dave ----
Old Jun 22, 2018 | 07:16 AM
Franklin2's Avatar
Franklin2
I recommend flooding the upper tumbler area with wd 40, and replacing the switch under the dash on top of the column. Make sure you use the alignment pin that comes with the new switch.
Bruce Ehrens
Oct 13, 2017 07:31 PM
rhol55
Sep 21, 2016 08:01 AM
Thumper19
Jul 26, 2012 09:14 PM
RShape
Jul 12, 2009 07:23 PM
Franco1961
Dec 2, 2003 04:54 AM
