aod 2-3 accumulator
Old Jun 21, 2018 | 12:09 AM
william16339's Avatar
william16339
aod 2-3 accumulator
I have an aod and its got to be a 89 or newer because it does not have the 1-2 shift accumulator but I was wondering what would happen if I left the spring out of the 2-3 accumulator...people say it really firms up the shifts? true or? thank you
Old Jun 21, 2018 | 07:18 AM
krooser's Avatar
krooser
I look into a TransGo shift kit...
Old Jun 21, 2018 | 11:20 AM
william16339
everyone says that and never answers the question. I’m just curious
Old Jun 21, 2018 | 12:50 PM
Redark1's Avatar
Redark1
if you do its going to shift harder. that's one of the older ways of making shifts harder. sometime the shift kits do a better job compared to removing the spring completely. try it you will know real quick if its too hard or not.
Old Jun 21, 2018 | 01:34 PM
william16339
you think it would be too hard. ? I believe my Aod is a 89 so it does not have the 1-2 accumulator
Old Jun 21, 2018 | 02:44 PM
Redark1's Avatar
Redark1
cant say for sure. don't think it would break the case or do any damage. if its still on stock mainline pressure it's only going to be so hard.
Old Jun 22, 2018 | 10:54 AM
Mudsport96's Avatar
Mudsport96
I can ALMOST promise you will find it too harsh. I would fine some big washers to put under the spring to shorten the distance it can compress vs taking it totally out.
Old Mar 20, 2025 | 09:24 AM
Conanski's Avatar
Conanski
Does the motor have an AOD specific flexplate on it? A C6/E4OD flexplate pushes the TC too far back grinding the pump which renders the trans non functional as soon as the engine is started.
Old Mar 20, 2025 | 10:13 AM
Hit Man X's Avatar
Hit Man X
You would have to park the accumulator, not remove it. Trans works together as a system, an actual valve body kit is what you need to increase shift quality and thus performance.
aaron ford
Mar 3, 2009 05:40 AM
kameronth
Dec 23, 2004 04:48 PM
f1001978
Apr 19, 2004 12:11 AM
desperado_18_2000
Mar 12, 2001 12:03 PM
