Low boost?
Old Jun 20, 2018 | 09:09 PM
'88 E-350's Avatar
'88 E-350
Low boost?
Stock '02 Excursion, using a scanner to see the boost though the OBD2 port. I get right about 15lbs. in totally stock condition. With the muffler disconnected at the factory slip joint it comes up to about 16.5 lbs. I borrowed my friend's Super Chips 1705 and on the highest setting I get about 20lbs with the muffler and 20.5 without. Cruising at 70 MPH, 2,000RPM I see about 2 PSI. I did all the tests with the wastegate hose connected, disconnected, then strapped closed with safety wire and there were no changes. Up-pipes look pretty clean for a 425K mile truck, just mild residue of black around the joints. All the air boot clamps are tight and no apparent holes.
From what I've read my boost seems low, especially with the tuner on it and the wastegate locked. It makes good power, but trying to figure out if something's wrong.
Old Jun 21, 2018 | 07:10 AM
Tugly's Avatar
Tugly
You can search the forum for a boost leak detector, and my up pipes have zero soot, as does everything else under the hood.
You appear to be just fine for those miles and stock parts (including airbox). A 4" exhaust and a Ford AIS intake will get you where you want to go. If you have future plans for bigger injectors or turbo, then you'll need a bigger intake than the AIS, I went with S&B.
Old Jun 21, 2018 | 07:48 AM
L-ight's Avatar
L-ight
From what I read stock boost is anywhere between 15-18psi. Im right around 16 psi on mine. Though you have yours chipped now so I can't help.
ExPACamper
20
Jun 23, 2017 09:00 AM
derek0525
13
Jan 19, 2016 03:57 PM
corksil
24
Jul 23, 2015 07:36 PM
nossliw
43
Jul 15, 2012 12:13 PM
74baja
Jan 28, 2009 09:58 AM
