Fuel Pump Burnout?
Old May 20, 2001 | 06:09 PM
theleetbeagle's Avatar
theleetbeagle
Fuel Pump Burnout?
So I've read different opinions and advice to the following question? Do in-tank fuel pumps need to be submerged in fuel as lubrication? If so, I've heard never to run the tank below half because it will burn the pumps out quicker if they aren't submerged in fuel. Sounds weird, though, because I've never heard of gasoline as acting as a lubricant. Anyone know a good, honest answer?
Thanks!
-Nick.
Everyone else includes their truck in their .sig file so here is mine:
1996 F-150 XLT Pacific Green Metallic
Mods: Perm mounted CB with Dual Cobra antennas, 3" body lift, 31" tires, emergency lightbar, 28" air horns, and a bunch of other smaller stuff.
Old May 20, 2001 | 11:10 PM
PAUL_2's Avatar
PAUL_2
Fuel Pump Burnout?
The gas acts as a coolant , the electric fuel pump motor bearings are sealed . Id say running the tank(s) consistantly below 1/4 full could shorten the life of the pumps .
Old Sep 10, 2001 | 09:11 AM
winfordr's Avatar
winfordr
Fuel Pump Burnout?
I think as long as the pump does not run dry you should be ok. That may be risky below 1/4 tank. The pump pulls fuel at the bottom and pushes it out at the top. That would seem to me to cool the motor sufficiently. I have only had one pump fail, and have had many different Fords with internal pumps. The one which failed locked up because of either running dry or foreign material in the gears. The motor was fine, as it ran ok after I cleared the lockup.
Winford
Old Sep 10, 2001 | 12:15 PM
theleetbeagle
Fuel Pump Burnout?
gman97005
General Automotive Discussion
Aug 26, 2013 09:52 PM
jmfrost
Feb 9, 2013 07:44 PM
Argess
Jun 30, 2009 12:04 PM
TN97STROKE
15
Jun 26, 2008 06:44 PM
Ford Breakdown
Aug 18, 2003 11:16 AM
