Stalling while driving
Old Jun 18, 2018 | 06:04 PM
NE Green Acres's Avatar
NE Green Acres
my 1989 Ford F-250 5.8 liter manual keeps stalling while I'm driving. About two months ago it died on me and left me stranded. It had no symptoms before that just died. Ended up changing the coil first didn't work then replaced the module and started up. But now the problem was it was stalling while driving. It doesn't stall right away first the gas power is out and once I hit the brakes is when it finally dies out. Ended up having to replace the fuel filter and fuel pump also. Problem still occurring. Anybody have this problem before. Pleasseee
Last edited by NE Green Acres; Jun 18, 2018 at 06:06 PM. Reason: Forgot to put something
Old Jun 19, 2018 | 08:34 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Is the ignition module in the distributor on this one?
I am of the mind to replace the coil, module and the PIP in the distributor as a preventive measure when you get to this point. Clean the shutter wheel in the distributor that triggers the PIP also.
I have some links to related threads but I don't have them with me. You could search with the username Subford and find most of them.
https://www.ford-trucks.com/forums/1...placement.html
Follow some links from that thread and search some user names for related information.
griffingt
Dec 2, 2010 09:28 AM
grasscutter
Jul 10, 2007 04:07 PM
rmalottwtes30
General Automotive Discussion
Sep 4, 2006 02:59 PM
Adam Kemmerly
May 2, 2003 05:24 PM
Bob R
Oct 2, 1999 09:26 AM
