data tag plate decode
Old Jun 17, 2018 | 09:56 PM
brutus 400's Avatar
brutus 400
I have a 1978 f250, on the firewall are two id tags. They are both the same. I can understand the vin but the rest of it I cannot. It looks like this.
F26SRAE4XXX 6-445
SA 133 BDY 4 R
1C46 REG CUS RKR
A FX BOTH
any ideas what all this means.
Thanks Brutus 400.
Old Jun 17, 2018 | 10:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F26SRAE4XXX 6-445 // SA 133 BDY 4 R // 1C46 REG CUS RKR // A FX BOTH
This is a "Buck Tag." The codes on Buck Tags are used by assembly line workers to assure the correct parts are installed that match the build sheet.
Most of these codes cannot be decoded.
If you want codes decoded: Warranty Plate riveted to the left door face below the latch. Safety Standard Certification Label glued to the B pillar below the striker plate.
DEZ_455
24
Jan 9, 2026 09:55 PM
ford-man
Nov 29, 2007 10:30 PM
stangt1
13
Jan 23, 2005 12:45 PM
tibbetts77
Oct 1, 2003 12:14 PM
