P02CD Code
Old Jun 17, 2018 | 07:05 PM
minnieub's Avatar
minnieub
P02CD Code
Check engine light came on and code P02CD is what was brought up. Truck runs ok but when hooked to our goseneck with a load doesn't seem to have as much power. It also showed Fuel Air Metering. Can't gind much
Old Jun 17, 2018 | 08:13 PM
shawn.snow's Avatar
shawn.snow
All Data doesn't show that as a valid DTC code. Can we get a little information about what truck you have? It may help us solve your problem.
Old Jun 18, 2018 | 06:28 AM
djousma's Avatar
djousma
A Quick google search turned up a couple of matches
https://www.ford-trucks.com/forums/1...dte-p02cd.html
Truck has a P code with no effective issues : P02CD : - Ford Powerstroke Diesel Forum
sounds like you may have a bad injector?
Old Jun 18, 2018 | 10:09 AM
minnieub's Avatar
minnieub
Truck is a 2011 F350 with 150,000 miles. Only notice a reduction in power when pulling a 35'goose with about 9000 lbs in. When not hooked up truck seems to run fine. Everything is stock. Everything I find on that code seems to talk about gas trucks.
Old Jun 18, 2018 | 10:19 AM
djousma's Avatar
djousma
The two links I provided in my prior post were both diesel related. You probably wouldn't notice the derate in power not towing. Probably going to have to have a shop take a peek. If an injector is going bad, the new one's serial number has to be programmed into the computer.
P02CD - Cylinder 1 Fuel Injector Offset Learning at Maximum Limit
Old Jun 18, 2018 | 03:48 PM
m-chan68's Avatar
m-chan68
Has an EGR cooler ever been replaced on this truck at any point in time? I once had a truck that had one replaced in its repair history seeping coolant from the bypass valve to cooler housing gasket, onto the top of cylinder #1 injector causing a dead miss. I don't remember if it set that particular trouble code though.
mfrancis84
Feb 25, 2020 11:19 AM
Tammie Cox
Exhaust Systems
Dec 17, 2018 08:32 AM
sandyc
6.7L Power Stroke Diesel
May 30, 2018 12:21 PM
Texas450
6.4L Power Stroke Diesel
Dec 17, 2010 10:52 AM
55F250
General Automotive Discussion
Sep 5, 2009 02:14 AM
