Dead block?
Old Jun 16, 2018 | 07:46 PM
Bmoodie10's Avatar
Bmoodie10
Dead block?
Already bored 060. Need to know before I take this any further. 6 out of 8 pistons have similar “grooves”
Old Jun 17, 2018 | 10:17 AM
78Puller's Avatar
78Puller
That looks like the piston scuffing the cylinder wall because the clearance was too tight. The right way to correct that is to have it bored and honed again to the right clearances.
Old Jun 21, 2018 | 05:36 PM
baddad457's Avatar
baddad457
If thats the E0AE block you have, youre playing with fire trying to use it. In another thread you mention it coming from a 79. If it is and its a D8VE casting then you could bore it another .020, depending on core shift. And if it has the A3A suffix, then I would seriously look into that as this casting had the hi-po main caps
Old Jun 21, 2018 | 08:35 PM
Bmoodie10's Avatar
Bmoodie10
we keep running into each other on this forum!! Trashed that block. Dead, kill it, make some art out of it, no worries. Told you a few days ago about picking up the ready to go block for good money spent. Super excited about the build now that the block is figured out. Took your advise about the head gaskets and purchased the correct ones from summit - I believe you were worried about deck hight on an 85 block that’s been worked over. Hopefully start assembly over the 4th.
Old Jun 21, 2018 | 08:38 PM
Bmoodie10's Avatar
Bmoodie10
once again, I know 85 block isnt the greatest. I feel like we should exchange email addresses and eliminate the middle man! Lol!
TMI
Jul 30, 2017 03:17 AM
idaho211
Oct 4, 2009 10:40 AM
countryF150
Oct 10, 2006 12:03 PM
LedheadELH
Jul 1, 2006 06:19 PM
chrowen
May 13, 2003 07:48 PM
