I have a cheap 2.5" front lift that was install by PO (2015 supercab 4x4). It feels like I have near zero caster. I do plan to drop the front 1-1.5", so that'll help a little. So, a few questions.
What's the OEM spec for caster on these trucks?
I see aftermarket caster bushings/bolts that state adjustment ranges of up to 2.5deg caster. What's the OEM adjustment range, and what's the downside of using an 'aggressive' caster bushing/bolt set? (I assume there's a limit of adding caster this way, sometimes from tire clearance in the wheel well.)
my research concluded that you cant adjust castor on a superduty 4X4. these trucks use a solid axle and the whole system rides on the pinon arms. using a level kit on these types of trucks has zero effect on castor. 2WD are a different story.
Maybe not adjustable as designed from factory? But these types of 'crash' bolts and bushings are common. From Rockauto for about $17. 2.25deg adjustability.
Also, raising suspension must cause at least a small change in caster, because the pinion radius arm rotates around a fixed point at the rear end of the arm. Maybe nearly zero change in caster.
You would be surprised what a small lift does to caster. Yes the bushings are the fix. Have a professional do it who has experience with the caster bushings. If I remember correctly spec for caster on the 2015 trucks in 4wd it ~3.0*. When guys bring in their lifter trucks that actually have a caster adjustment built into the new arms I usually aim for ~5.5-6*. Seems extreme but it really helps with larger tires.
Below is obviously and after market radius arm, but it shows an off-center bolt/bushing on the lower front mount point. This allows one to push/pull the lower mounting point on the axle forward/back, changing the caster angle. I'm 99% certain the cheap $20 caster bushings work the same way on an OEM radius arm.
that would be great ......but my 2010 f-450 does not have one. I have a Dana super 60!axle if it makes any difference.
Yes, it must be the F-450 because my 2005 F-250 4x4 I had and my current 2011 F-250 4x4 I have now both have the bushing. I have a both the adjusting bushings and a 4" radius arm lift with additional castor adjustment and it has made a HUGE difference.
Powerstrokehelp has a vid on you tube where he says you should aim for as much as you can get but try to be at least at 3*. I know not everyone likes him so I will not link the vid.
I am a suspension tech, and yes that cam goes on the Dana 60 also, on the upper ball joint, do them all the time, both my trucks have them, just did a 550 a couple days ago.
