The Parameter Identification (PID) mode allows access to certain data values, analog and digital inputs and outputs, calculated values, and system status information. Throughout the manual, there will be references to PID values. PID Data Monitor and Record can be accessed from the Rotunda New Generation Star (NGS) Tester 007-00500 (or equivalent) through the Diagnostic Data Link menu.
Selecting Parameter Identification (PID)
Connect the NGS Tester to the DLC under the dash. Turn off accessories. If vehicle is equipped with an auxiliary powertrain control (rpm control), it must be turned off to perform self tests.
Perform the necessary vehicle preparation and visual inspection. Refer to Quick Test
Select VEHICLE & ENGINE SELECTION menu.
SELECT NEW VEHICLE, YEAR & MODEL.
Select DIAGNOSTIC DATA LINK.
Select PCM - POWERTRAIN CONTROL MODULE.
Select PID/DATA MONITOR AND RECORD.
Turn key on or start vehicle.
Follow operating instructions from the menu.
Select the PIDs, press START to begin monitoring.
Parameter Identification (PID) List
AcronymDescriptionMeasurement Units4x4L4x4 Low SwitchON/OFFACCSAir Conditioning Clutch StatusON/OFFAPAccel Pedal Position SensorVoltsARPMDESAncillary Engine Speed DesiredRPMBAROBarometric Pressure SensorPSIBARO VBarometric Pressure Sensor ActualVoltsBOOBrake ON/OFF SwitchON/OFFBPABrake Pressure AppliedON/OFFCCSCoast Clutch SolenoidON/OFFCPPClutch Pedal PositionON/OFFCPP/TCSClutch Pedal Position/TCSON/OFFCRUISECruise Control Mode (Driving)ON/STNDBY/TAPUP/TAPDNDTC CNTDiagnostic Trouble Code CountDTC No.EBPExhaust Back PressurePSI (Absolute)EBP VExhaust Back Pressure ActualVoltsEOTEngine Oil Temperature°FEPC*Electronic Pressure ControlPSIEPC VElectronic Pressure Control ActualVoltsEPRExhaust Pressure RegulatorPercentFUEL PWFuel Pulse WidthMillisecondsGEARTransmission Gear E4OD Only (Driving)Trans. GearGPCGlow Plug Control Duty CyclePercentGPC TMGlow Plug Control TimeSecondsGPL TMGlow Plug Lamp TimeSecondsIAT*Intake Air TemperatureDegreesIAT VIntake Air Temperature ActualVoltsICPInjector Control Pressure SensorPSIICP VInjection Control Pressure ActualVoltsIPRInjector Control Pressure RegulatorPercentIVSIdle Validation SwitchON/OFFMAPManifold Absolute Pressure SensorPSI (Absolute)MAP HManifold Absolute Pressure ActualHzMFDESMass Fuel DesiredMilligramsMGPManifold Gauge PressurePSIPBAParking Brake AppliedON/OFFRPMEngine SpeedRPMSCCSSpeed Control Command SwitchVoltsSCCS MSpeed Control Command Switch ModeModeSS1Shift Solenoid No. 1 — E4OD OnlyON/OFFSS2Shift Solenoid No. 2 — E4OD OnlyON/OFFTCCTorque Converter ClutchON/OFFTCILTransmission Control Indicator LampON/OFFTCSTransmission Control SwitchON/OFFTFT V*Transmission Fluid Temperature Sensor ActualVoltsTORQUEEngine TorqueLb/FtTPRELLow Idle Throttle PositionVTRTransmission Range Sensor PositionPRNDLTR VTransmission Ranger Sensor ActualVoltsVFDESVolume Fuel DesiredCubic MillimetersVPWRVehicle Power SupplyVoltsVREFVehicle Reference VoltageVoltsVS SETVehicle Speed SettingMPHVSSVehicle Speed SensorMPH
* Designates PIDs that show PCM calculated values during fault.
NGS TESTER — DRIVER-OPERATED CONTROLS CHECKPIDOperator's SettingNGS Tester ReadingEEC PinVoltagePinpoint TestAPFoot OFF of AcceleratorApprox. 0.6V89Approx. 0.6VEFoot ON at WOTApprox. 3.8 VApprox. 3.8VIVSFoot OFF of Accelerator
Foot ON AcceleratorOFF
ON50V
B+AABOOFoot ON Service BrakeON92B+KFoot OFF Service BrakeOFF0VBPAFoot ON Service BrakeON310VPFoot OFF Service BrakeOFFB+CPP/TCS(M5OD)29NClutch DepressedON0VFoot OFF Clutch PedalOFFB+PBAParking Brake ONON40VQParking Brake OFFOFFB+CPP/TCS(E4OD)29AKOD CNCL Button Held InONB+OD CNCL Button ReleasedOFF0 VTR(E4OD)64AMPRNDL in PP/N4.45VPRNDL in RREV3.64VPRNDL in NNTRL2.87VPRNDL in ODOD2.87VPRNDL in OD with OD Cancel Light ONDRIVE2.13VPRNDL in L2MAN21.40VPRNDL in L1MAN1.71VTCIL(E4OD)79AKAfter Key ONOFF0VPush OD Cancel (Latch)ONB+Push OD Cancel (Unlatch)OFF0VSCCS M(Speed Control)61FAfter Key ONOPEN6.68VSpeed Control OFFOFF0VSpeed Control ONONB+SET/ACCELSET AC2.74VCOASTCOAST.68VRESUMERESUME4.66VCRUISE(Speed Control/When Driving Only) OFFOFF61FONSTNDBYSee AboveSET/ACCEL
(After Pressing)Tap Up
(Active)COAST
(After Pressing)Tap Down
(Active)4x4L(Transfer Case Shifter)14AD4x4H or 2HOFFB+4x4LON0 VACCS(A/C Controls)41AEMAX/NORM AC or MIX/DEF with A/C Clutch ONONB+Floor or Vent or A/C Clutch OFFOFF0 V
That has been one of the issues with the software that FTE is run on.
You should see what it does to the formatting of a PM that I send out as a form letter.
It's so screwed up I think it faster to just retype it each time. But there is a trick.
Click the Source button and they try it. That will give you the option to enter the HYML coding.
Then just click it again or hit Preview.
