Squishy brakes
Old Jun 14, 2018 | 01:23 PM
Billshea1's Avatar
Billshea1
Squishy brakes
everyone helped me with my last problem so I’m hoping someone can point me in the right direction with my squishy brakes. We did a disk convertion in the front with new lines and good calipers. Rear drums are new and adjusted. Probably went through a gallon of brake fluid bleeding it and still squishy. Any ideas?
Old Jun 14, 2018 | 01:26 PM
Billshea1's Avatar
Billshea1
Also new master and power booster
Old Jun 14, 2018 | 01:41 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Did you bench bleed the master cylinder? If not that can cause it.
Here's a Wikihow on it.
https://www.wikihow.com/Bleed-a-Master-Cylinder
Chad
Old Jun 14, 2018 | 01:45 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Incidentally, that article mentions how a mechanic would use a vacuum bleeder. Those or a pressure pot can sure help.
I like my pressure pot but they are not cheap. You might be able to rent one or the other, too.
Chad
Old Jun 14, 2018 | 02:04 PM
Crop Duster's Avatar
Crop Duster
What differential/proportioning valve did you use? The stock Ford ones have a bleeder valve on them that must be pulled out or pushed in, in order to get fluid to flow to the front brakes. You will still get fluid but you may never get all the air out unless that metering valve is held open.
Old Jun 14, 2018 | 02:33 PM
ultraranger's Avatar
ultraranger
Check all fitting connections for any fluid leaks.
Old Jun 14, 2018 | 08:28 PM
Billshea1's Avatar
Billshea1
So I did bench bleed the master but didn’t realize I had to mess with the proportioning valve. The convertion used 78 f100 parts. I’ll try that. How can I tell if I have a bad valve?
Old Jun 15, 2018 | 03:52 AM
Crop Duster
Brake bleeding
Here is a page from the chassis manual, "sort of", it's hard to scan as this thing it is about as thick as a New York phone book. Forget that bleeder tool, they ain't none to be had. You will have to make your own or get someone to lay under there and hold that pin out or push it in depending on which system you used.
Old Jun 15, 2018 | 08:10 AM
AlsRyd66's Avatar
AlsRyd66
Check out the rod length on the power booster. It might not be long enough to go all the way into the master cylinder. Especially if your power booster is aftermarket. That was my issue after doing disc/drum total replacement from drum/drum. I did all new to include lines, calipers rotors, etc.
Old Jun 15, 2018 | 09:26 AM
Billshea1's Avatar
Billshea1
We had to lengthen the rod as well
Holehawgg
Jan 6, 2015 01:17 PM
shameless
Oct 1, 2011 03:25 PM
Green Streak
Apr 17, 2010 11:43 AM
ttamwhit
Feb 26, 2009 06:48 PM
Dan-79F350
May 17, 2000 03:19 PM
