Insterment cluster lens
Old Jun 13, 2018 | 09:45 PM
fivestarmmd's Avatar
fivestarmmd
Who has the green lens for turn signal and red lens for hi beam indactor. What is correct screw size that holds door panels ?
Old Jun 13, 2018 | 09:57 PM
Christmas's Avatar
Christmas
The lens is just piece of green plastic sheeting glued in, craft store. #8 sheet metal stainless semi domed flat head, Ace hardware. Hope this helps
Old Jun 14, 2018 | 08:21 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Original lens were not simply sheet but that will work as a replacement. I have a couple of the high beam indicators but none of the turn indicator.
Chad
Old Jun 14, 2018 | 08:55 PM
fivestarmmd
Looks like need new u nuts. Most are stretched from bigger screws. Out of 4 parts trucks there are no good turn,hi beam lens. Making a 64 F700 HD 330 legal. Been slow project.
Old Jun 15, 2018 | 11:36 PM
62fordF250's Avatar
62fordF250
I cut some squares out of a green plastic container lid and a red one. Stack as many squares as you want to make it dimmer and glue or tape them on. That is, unless you are doing a full restore and want everything perfect.
Old Jun 16, 2018 | 05:09 PM
RangerMercMan's Avatar
RangerMercMan
80's and 90's vehicles have red green and blue pieces of sheet plastic that you can make work. No it will not be concours correct but legal.
tonyford
Escape & Escape Hybrid
Oct 14, 2015 10:43 AM
Not Fragile
May 18, 2015 11:49 AM
Redmanbob
Electrical Systems/Wiring
Feb 11, 2007 05:40 AM
rmalottwtes30
Jul 4, 2005 05:45 PM
arnolan
Apr 14, 2003 12:18 PM
