Truck 390s have sunken pistons and low compression.
Your mods may be worth some power, but how is the rest of the engine? If your motor has low cylinder pressure on one or more holes, you may be below the stock numbers.
assuming i I have good compression, what do you think I’m pushing? 230, 240hp? Truck also as 4.10s and a posi, I know that doesn’t add horsepower but helps off the line for sure
wiki says
8.2:1 — 201 horsepower (150 kW) net at 4000 rpm and376 lb⋅ft (510 N⋅m) at 2600 rpm
1972–1975 Trucks
750 to big for a low compression 390 .
yeah ive heard that from a few people and haven’t been able to get it to run quite right. It sat for 7 years so I rebuilt the carb on it but still isn’t quite where I want it. Tomorrow I’m getting a 650cfm edelbrock which should do the trick
carb ,manifold and exhaust not going to make huge number changes on a otherwise stock truck motor . if your lucky probably 220
cam and compression is where the real hp and tq gains are
The 750 is only too big if it's got mechanical secondaries. If it's a vacuum sec carb, it's fine. You won't see much difference downsizing to a 650. Don't know about tuning those carbs, but with a Holley you can tailor the secondary opening to fit the engine's needs. I've run a 3310 Holley 750 on an Explorer 302 and it ran fine with it. It only used the flow it needed with it's vacuum secondaries.
4.10's multiply the torque which is the same as adding HP
it is vacuum secondaries but I need a new carb anyways and figure 650cfm should do the trick
forgot to mention I also have an hei style distributor
I'd agree, you likely added 10-15 HP with the upgrades. Nothing earth shattering and likely hard to measure(we're talking about a 10% increase). These were horribly detuned smog motors.
That 750 will work, since it is basically a 375 cfm 2bbl and only gives you more fuel when the motor needs it(once secondaries are tuned properly). Not sure I would put a 650 DP on it. Even with the 4.10 gears, it might not accelerate fast enough and just feel lazy if you go WOT at too low of RPM. It might "sound" like its doing something, but I bet if you actually timed it you would not see an improvement.
Not sure how Edelbrock measures CFM on their carbs, but with a 750 Holley, the primary side is equivalent to a 500 cfm 2 bbl. Holley 2 bbls are rated at 3" HG drop, 4 bbls are rated at 1.5"HG. The Holley 500 cfm is basically the primary side of a 750 DP 4 bbl. Same throttle bores and throttle blade diameter.
its a 650cfm edelbrock, Thunder AVS. Vacuum secondaries I believe
