Sponsored by: Real Truck
Surging issues, 6.0
Old Jun 13, 2018 | 06:43 PM
Railmanmatt's Avatar
Railmanmatt
Surging issues, 6.0
Hello, all. First post, so if it has been covered elsewhere, I apologize in advance. I have a 2003 F250 King Ranch with the 6.0 diesel. It has 380000 miles, and ran like a top until I was at cruising speed on my way home from work.
The RPMs just started surging, and wouldn't stop until I got it home. I also had light smoke out of the tailpipe, and loss of power. I replaced the ICP and the plug. No fix. I then took out the turbo and cleaned the vanes and put that back together. I'm planning on replacing the cam and crank sensors this Friday, because I got a p0214 and a p0217 code. I will also check the wiring harness when I install the sensors. Is there anything else I should be looking for? Thanks.
Old Jun 14, 2018 | 08:43 PM
Railmanmatt
Ok, replaced the cam sensor tonight, now it won't start. I checked the wiring harness, and it looks to be in excellent condition. The tach also doesn't move while cranking. Should I replace the crank sensor next and see what happens?
Old Jun 14, 2018 | 11:23 PM
texinwa's Avatar
texinwa
put the old cam sensor in and get her running again first
Old Jun 15, 2018 | 12:25 PM
Railmanmatt
Will do, it didn't look bad, anyway. The one I bought was Motorcraft, I assumed it freaking would be ok out of the box.
Old Jun 15, 2018 | 04:52 PM
OneCylinder's Avatar
OneCylinder
Monitor the EOT during the surging epesodes. My 6.0 has had -17 thru 60 deg F reading while surging. The engine was actually at operating temp. The PCM causes more fuel to be injected when temps are under 60 deg. This will cause the engine to run bad and surge.
Old Jun 16, 2018 | 02:08 PM
Railmanmatt
Ok, old cam sensor is back in, and the truck still won't start. Could it possibly be a Ficm issue at this point?
Old Jun 17, 2018 | 03:00 PM
Azryael's Avatar
Azryael
Here's a great video to guide you along to test your FICM, just to rule it out.
Old Jun 18, 2018 | 06:40 AM
Railmanmatt
Thanks for the info, I might check the cam sensor plug, tonight, also. What type of voltage or ohms should I look for when testing that?
Old Jul 17, 2018 | 03:21 PM
Railmanmatt
Okay, I have an update. I reinstalled the cam sensor, and replace the crankshaft sensor. That's what it was. It will end up being a $25 sensor.
xcrsp440
Jul 23, 2024 01:05 AM
xcrsp440
Jul 2, 2018 10:28 PM
ken taromino
Apr 29, 2016 07:54 PM
Nphip
Aug 23, 2015 01:04 PM
viperrtblck
Oct 10, 2006 09:12 PM
