6.0 trouble starting
Old Jun 13, 2015 | 03:46 PM
Nphip's Avatar
Nphip
I have a 2005 with the 6.0. It recently started loosing power and threw a code for a cam sensor so I swapped cam sensor. After that now it won't start all the time. If it does start I have to keep it above 1000 rpm to stay running, if I try to idle it the engine dies. No codes are showing now. Any ideas with what to look for next? Any help is appreciated.
Old Jun 13, 2015 | 05:30 PM
rhjj's Avatar
rhjj
Get a scan gauge or edge insight to monitor vitals.That will help with diagnosis.
Old Jun 13, 2015 | 06:09 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I'd also double check the sensor install, they kinda snap into place. You can get it installed "crooked" so to speak and the bolt will tighten down. Also take a hard look at the connector for oil, pins pushed back and visible part of the harness for chafing.
It's also common to get codes for cam/crank sync with a lot of cranking and no start. That may have been what happened and the problem is elsewhere. That's the reson for the diag tool recommendation.
Old Aug 23, 2015 | 01:04 PM
Dieseldoctorsllc's Avatar
Dieseldoctorsllc
check your wiring loom good place to start is from the crank sensor up. Lot of problems with injectors to crank and cam sensor issues are caused from wire looms on top rubbing and hitting a stud.
softpickle
Oct 31, 2017 04:57 PM
chaser1602
Oct 27, 2017 07:41 AM
ToolmakerRob
Jan 7, 2017 08:49 PM
bigtdriver
Sep 27, 2013 10:10 PM
retiredinstructor
Feb 28, 2012 03:45 PM
