1996 fuel pump question
Old Feb 19, 2011 | 11:46 AM
LADNAR's Avatar
LADNAR
96 f150 so high pressure pump in tanks. Is tyhere another on frame rail like older trucks have? The reason is the rear tank doesnt seem to pump as much fuel when I go to that tank, engines sputters and dies when going down tyhe road. I just switch back to front tank and hope we make it back to town. Been doing this for couple years, just been running front tank and trying to switch when really low on fuel. Ive been adding some fuel conditioners in rear tank also. Another part is that the rear tank seems to fill up. Example: fuel has seeped out the fill area and stained the paint. Also sometimes can here pressure in this tank after shutting off. I have not tried to hear if rear pump is running or not though.
Old Feb 19, 2011 | 11:57 AM
92nite351's Avatar
92nite351
maybe the filter on the end of the fuel pump.....clogging? kinda wierd havnt heard of many issues like this
Old Feb 19, 2011 | 12:38 PM
Conanski's Avatar
Conanski
You have 2 problems.
1. Either the rear pump is dying or it's not getting a full 12v due to a corroded connector or bad wiring.
2. You have the fuel transfer problem due to a stuck check valve in the rear fuel delivery module, the fix is to replace the FDM.
FYI.. there is no frame mounted pump or switching valve on these trucks after 1989 just a high pressure pump in each tank.
Old Feb 19, 2011 | 04:39 PM
True Blue 94's Avatar
True Blue 94
new pumps aint that expencive and they are pretty easy to do. thats my guess to the problem. I can only run my front tank due to holes in the rear one and this was happening to me on the front tank. super doggy and no power. Does it cut out like it gets no fuel after a slight bit of throttle is used? if so it is you pump. i did a filter too just to eliminate that problem.
Old Feb 19, 2011 | 04:50 PM
LADNAR's Avatar
LADNAR
thanks guys
Old Feb 24, 2011 | 09:24 AM
LADNAR's Avatar
LADNAR
Next question . Ive always dropped the fuel tanks when Ive done pump or tank replacement, but others have just unbolted and slid the bed back to get to the pump from the top. My delima is Ive got a gooseneck ball in the bed of the pickup id have to unscrew. It hasnt been out for quite a while and im sure its rusted on the exposed threads so that wouyld slow me down for an hour or so. Also the regular bed bolts may be a B****. Also would neeed to unhook electric from tail lights but that would be easiest part Im sure. If I did take box off I could really clean around frame rails and tanks. Opions please.
Ex-ChevyOwner
Oct 7, 2015 09:14 PM
SteelSteeds
Aug 16, 2015 07:03 AM
Coccyx
Mar 25, 2014 08:47 PM
SSellers
20
Dec 24, 2013 12:47 AM
lud04X
Dec 3, 2011 09:58 PM
