Sponsored by: Real Truck
PCM Reprogram
Old Jun 13, 2018 | 01:29 PM
MTP55's Avatar
MTP55
PCM Reprogram
Google says this PCM Reprogram is for an excursion. My truck is an F-250. What difference does this make to the truck?
Old Jun 13, 2018 | 02:07 PM
Just Strokin's Avatar
Just Strokin
You are worrying over nothing. The Excursion used the 7.3 as did the Super Duty trucks. They use the same software in the computer. When I used Yahoo to search, it showed not only the Excursion but also for the F250/350.
FYI, the Excursion is built in the Kentucky Truck Plant on the same assembly line as the Super Duties.
Old Jun 13, 2018 | 03:02 PM
MTP55's Avatar
MTP55
Right I knew that theyre essentially the same thing. Just didn't know if there was reason that they would have redone it a year after it was built. Maybe the original was faulty.
Old Jun 13, 2018 | 03:47 PM
Just Strokin
It is not uncommon to have PCM program updated. You do not see the stickers as prevalent as once were about a reprogram unless it is a total recall by Ford of a vehicle model to correct an issue. I had my 2015 PM updated due to the jack hammering issue and the EGT sensors shutting down the trucks. My 2015 was not having a problem but asked it be updated.
Old Jun 13, 2018 | 04:18 PM
MTP55's Avatar
MTP55
Ok. Thank you.
gi1gamesh
Feb 14, 2017 08:12 AM
joneskl
Apr 5, 2016 11:56 PM
F2502011
Jun 5, 2014 11:08 PM
GuateKingRanch
Apr 11, 2013 06:50 AM
noplugs
Apr 8, 2011 09:04 AM
