Electrical problem
Old Jun 13, 2018 | 03:28 AM
jim6liter's Avatar
jim6liter
Electrical problem
Can anyone lean me in the right direction here please? Thanks
Old Jun 13, 2018 | 08:13 PM
Maxium4x4's Avatar
Maxium4x4
Well that is a new one for sure.... Brake and wiring harness must be rubbing since the two coincide with each other.
And just when you think we have seen it all.......... Bumping back to the top and I am sure a few will be along to help out.
Old Jun 13, 2018 | 08:57 PM
Yahiko's Avatar
Yahiko
This is the 2004 F250?
When you press on the brake does the speedo go up in proportion to how much you depress the brake?
Do you have a trailer brake controller in this truck?
I'll have to do a little digging into the manuals on this one for sure.
Old Jun 13, 2018 | 11:09 PM
jim6liter's Avatar
jim6liter
yes I do have a brake controller
Old Jun 13, 2018 | 11:17 PM
Yahiko's Avatar
Yahiko
The factory one talks to the braking system that handles the ABS and the PCM talks to everything.
Try the brake controller lever and see what that does next time you in the truck.
Old Jun 13, 2018 | 11:24 PM
jim6liter's Avatar
jim6liter
My brake controller is after market, I definitely will try that. It’s intermittent, when it does it I will give it a try. Thanks
Old Jun 14, 2018 | 12:30 AM
Yahiko's Avatar
Yahiko
Before you get too wild take a good look up under the dash around the brake switch and all it's wiring.
Do some wiggle testing on the wires and see it something shows up. Also run your finger down each
wire and feel for nicks an/or abrasions.
Wilmax
Dec 16, 2012 10:24 AM
largemouthman
Jul 21, 2006 12:41 PM
LHeidinger
All Things Towing
Nov 17, 2005 06:17 PM
