Brake Contoller
Old Nov 13, 2005 | 06:46 PM
LHeidinger's Avatar
LHeidinger
Brake Contoller
I have a 2004 F350....wiring harness for aftermarket brake contoller is under dash. I bough a Hoppy Impulse along with a "plug in simple" connector. Sounded easy ! I plugged one end into factory installed wiring..the other into brake controller. I keep getting an E1 message on the contoller which means...trailer not connected. I checked all connections....
Any thoughts as what I should trouble shoot next?
Thanks for any help
Lisa
Old Nov 13, 2005 | 07:18 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Is the trailer hooked up to pickup? My controler shows a red light until I hook up the trailer.
Old Nov 14, 2005 | 09:31 PM
submakr's Avatar
submakr
What brake controller do you have?
Old Nov 15, 2005 | 11:15 AM
CmprSpecial's Avatar
CmprSpecial
I think it's a Hoppy Impulse. Never heard of that brand myself..
Wish I could help
Old Nov 15, 2005 | 11:54 AM
submakr's Avatar
submakr
Lisa,
Do you still need help on the controller?
Old Nov 15, 2005 | 01:24 PM
LHeidinger's Avatar
LHeidinger
Thanks so much for the quick responses and offers of help.
I think I have solved my problem. I was also using a adapter to connect the truck and trailer. ( 6 wire round trailer connector to 7 RV blade truck.) I got all the wiring diagrams and traced everything. I needed to open the adapter and swap 2 wires. The black( was in center-battery) and the Blue ( Electric brakes) needed to be swaped to match how the trailer was wired.
I forgot to mention in my first post, that besides the E1 message I was getting which means trailer is not connected the trailer brakes were also locked up. This led me to believe I had wires not matching.
Hope this helps someone in the future.......by the way. When I opened up the 6/7 adapter....all the wires were soldered...except the black and the blue. Looks like they were made to be swapped if needed.
Lisa
Old Nov 15, 2005 | 01:32 PM
submakr's Avatar
submakr
Great job, good luck!!
Old Nov 16, 2005 | 08:13 AM
Papa_J's Avatar
Papa_J
I'm having a similar problem with my 05 F-250 5.4L. Didn't get the TCS, because I couldn't find an 05 that had it. Problem is that when I hook up to my tandem auto trailer with electric brakes via a 7-pin to 5-pin converter, the trailer brakes lock up. Didn't happen on my 01 F350 PSD, so I can only guess that there's some kind of wiring issue with the 05. Any thoughts?
Jim
Old Nov 16, 2005 | 11:54 AM
bigredtruckmi
Veteran: Navy
Might go to dealership and ask what the difference is between the 01 and 05 wiring and do the correction in the adapter.
Old Nov 17, 2005 | 01:25 PM
Papa_J's Avatar
Papa_J
Thanks. I'll give that a shot. It couldn't hurt.
Old Nov 17, 2005 | 06:17 PM
94_turbo's Avatar
94_turbo
lisa--after working at ford for a while--id say switch it back to the way it was--and switch the trailer wires--as many trailers ive wired--either were rewired by the owner--wrong--or the trailer manu had them wrong--for whatever reason -- there is a industry standard code to wire by--
