Wing vent glass too big, will sand it down
I had new glass put in my wing vents when my 55 F350 by Safelite when my truck was in the body shop. The glass is a bit too big the driver's side can not close properly. The passenger side closes but I think the division bar needs moved forward a bit as the window goes up and down hard.
I called Safelite and spoke to the guy that put the glass in the vents. He said I could bring them in and he would fix them. I don't feel like taking them out so I asked if I could drive the truck to his shop. He said I could grind them down with a belt sander. He said use a 70 or 80 grit belt. I figure I need to shave off about 1/16th inch.
Can anyone give me any tips before i try this?
It's the back of the glass hitting the division bar on the driver's side. You can see the glass stick out beyond the frame on both vents. It doesn't do that on my 54 vents.
Received 4,200 Likes
on
yes, I know. But if the vent glass is too big then I can't move the division bar forward to allow the window to go up more easily. I can't move the division bar back more since the door glass is tight already. I did not replace the door glass so it is not a matter of it being too wide.
Thanks!
So the general consensus is to have the glass shop do it. I will have to call him to see when I can bring my truck to him.
Thanks!
When I set my wing vent glass i pushed them too far into the frame and then had a gap at the division bars. You can realistically only adjust them so far without compounding 1 problem into 2. I had to slide the glass back out of the frames a bit to close the gap.
in your situation is the glass pushed all the way into the channel? If it can slide in a bit further would maybe fix the problem?
good luck with it.
good luck with it.
I had the same problem on my 52 wing windows.I worked for a glass fabricator and they took 1/8” off the vertical edge.The door window was a little tight after adjusting the division bar the best I could. I had all new fuzzies in so I took a 1/4” w x2x12 piece of wood, slid into the channel and a few firm raps up and down the front and back channels did it. Windows glide up and down like new now.
Im thinking a 1/8 to 1/16 inch will do it. The guy said to draw a straight edge line with a sharpie before I begin.
