Blower redirect help
Old Jun 11, 2018 | 07:36 PM
johnsonjf's Avatar
johnsonjf
Good Evening,
I have a 04 Excursion, Limited, 6.0 PSD. Currently the AC is blowing out the defroster vents, I know this is the sign of a vacuum leak. I have checked the lines going to the front hubs, happened after I worked on them last time. The lines are tight, the connections are secured with double zip ties 180 degrees out from each other. I'm guessing it could be the o-rings on the locking hubs themselves, going to look for new o-rings and install them. However, I am about to take a long trip and will need the AC blowing out the normal vents to help keep everybody cool. Is there a work around to get the damper in the airbox closed so the air is directed out the dash vents?
Thanks,
Jeff
Old Jun 11, 2018 | 07:56 PM
rwoodhull's Avatar
rwoodhull
Is the vacuum pump working?
Old Jun 11, 2018 | 08:38 PM
johnsonjf's Avatar
johnsonjf
I just looked on YouTube and found a diagnosis procedure for the pump, will be doing that tomorrow morning.
Jeff
Old Jun 12, 2018 | 11:57 AM
johnsonjf's Avatar
johnsonjf
It was a bad vacuum pump, changed it this morning and everything seems to be working fine now. Thanks
Old Jun 12, 2018 | 02:54 PM
SmackDaddy's Avatar
SmackDaddy
Yep, such a great system that ties the vacuum hubs and blend door to the same pump! I had to replace my vacuum pump and went ahead and deleted the vacuum lines to the hubs and installed manual locking Warns to hopefully eliminate the nonsense.
ithaca1230
Aug 13, 2019 08:40 AM
DarkyDizzle13
Jun 26, 2018 03:35 PM
ddiercks
Jul 13, 2013 06:00 AM
DGMFORD
Jan 7, 2010 12:31 AM
Moe fish
Aug 23, 2006 07:08 PM
