AC only blowing from dash
Old Aug 12, 2019 | 09:36 AM
ithaca1230's Avatar
ithaca1230
Just made a awesome trip to Avon NC on the outer backs. When we packed up trailer and got ready to go the AC would only come out of the dash. This has happened before and I usually just lower the fan speed to the lowest setting and it would change over to the dash vents. This time it didn't work tried a bunch of times and took a peek at the vacuum pump but nothing. Any suggestions. Thanks
Old Aug 12, 2019 | 09:56 AM
ArmyLifer's Avatar
ArmyLifer
Do you still have the auto 4x4 hubs? If they work then it’s something else. If they don’t work then it could be vacuum pump or a vacuum line leak. The rubber hoses to the knuckles could be toast if they are original.
Old Aug 12, 2019 | 01:20 PM
ithaca1230's Avatar
ithaca1230
No I have swapped them for warn hubs. I will have to check the vacuum lines again
Old Aug 12, 2019 | 05:35 PM
projectSHO89's Avatar
projectSHO89
What do you mean by "comes out of the dash"? That's where it's supposed to come out.
Old Aug 13, 2019 | 07:42 AM
ithaca1230's Avatar
ithaca1230
sorry I meant out of the vents to the windshield only. It will not change to blow out of any other vents
Old Aug 13, 2019 | 08:40 AM
projectSHO89
Either your vacuum pump isn't running or you have a vacuum leak.
ithaca1230
Jul 19, 2020 10:25 AM
651_F350_KR
Jan 16, 2018 07:22 PM
white04kr
Jul 18, 2011 04:36 PM
rangerbob406
Jun 3, 2008 08:39 AM
Flame Out
Jan 22, 2007 05:23 PM
