Left turning radius decreased after alignment
Old Jun 11, 2018 | 07:46 AM
EX40's Avatar
EX40
Passenger side tie rod snapped a couple weeks ago. I replaced the tie rods both and drag link myself. Took it to local frame & axle shop a couple miles down the road because the NTB I would normally use is about 15 miles away and didn't want to drive that far.
Here's my problem. Got the truck back and the left turning radius is off. Get about 2 full turns of the steering wheel before lock. What could be the cause? Should I look at the adjustment sleeves on both. I've got my old parts to compare.
BTW, I immediately called the shop tht afternoon and they want to tell me its normal. Also stated how off the toe was which leads me to believe they don't want to rectify the problem. I don't trust them at this point now anyway.
Is this something I could possibly correct myself if I leave the wheels on the ground and adjust the sleeves? I can't think of anything else it may be.
Old Jun 11, 2018 | 07:50 AM
housedad's Avatar
housedad
Yeah, I'd say they screwed it up. Don't go back to them. God knows what else they screwed up if they got something so simple so wrong. Get it double checked somewhere more reputable. If you do it yourself, make sure you turn both sleeves the exact same amount. Just my opinion, as I have never run into that type of issue before.
Old Jun 11, 2018 | 09:02 AM
Greenscobie86's Avatar
Greenscobie86
Check the pitman arm position. Sounds like the steering gearbox wasn't centered properly to me. I dealt with this issue when replacing my steering gear with a snapped sector shaft. Basically you can count the amount of times the steering wheel turns and center up the pitman arm/steering gear from there. IIRC I got about 2.5~2.75 turns to lock in each direction, give or take with some play. After you catch the "middle" of the gearbox you can set the drag link length. Don't bother trying to remove the steering wheel either to take up the difference, it only fits one way on these trucks.
All of this isn't very hard to do btw, just a little time consuming and fiddly.
Old Jun 11, 2018 | 09:35 AM
pirate4x4_camo's Avatar
pirate4x4_camo
I’d tend to side with scobie that the box wasn’t centered when you put the new tie rods on and the shop didn’t correct it.
if you don’t like the shop you took it to then have your normal shop correct it. It will need to be aligned again anyhow so you are not saving any money by doing it yourself .
Old Jun 12, 2018 | 10:32 AM
EX40's Avatar
EX40
I checked out the turns of the wheel. Left I get 1 full turn, Right about 1 & 3/4. Had my son turn wheel until it stopped in both directions. Nowhere near the steering stops.
Old Jun 27, 2018 | 09:27 PM
BunnyFluff's Avatar
BunnyFluff
4wd Low
Similar thing happened to me after I had my tie rods changed out. It ended up being the steering damper was not located properly. Easy to check, just disconnect it.
Old Jun 29, 2018 | 09:06 AM
EX40's Avatar
EX40
I thought I'd posted back. I end up taking it back to the shop and they did point out that the steering damper wasn't located properly. So it was my error.
All is well now.
Lovin193
1997 - 2003 F150
Mar 3, 2017 11:42 AM
Dezl Newbie
13
Dec 27, 2016 03:19 PM
khakushia
Feb 11, 2013 03:14 PM
hdfe
1978 - 1996 Big Bronco
Jan 20, 2010 08:26 AM
Mats Nilsson
Mar 16, 2006 03:23 PM
