Sponsored by: Auxito
Offset/not centered steering wheel
Old Feb 22, 2017 | 11:04 AM
Lovin193's Avatar
Lovin193
I'm new here and not sure if I'm posting this in the right area. Any help is appreciated. I have a 1999 f150 XLT 4x4 5.4 V8. I recently got side swiped hit and run during the night when I was sleeping. I think they messed up my steering components because now when I'm driving straight, my steering wheel is about 45° to the left. Steering is still spot on, no slack when turning. I recently replaced the tie rod ends and then got an alignment so I don't think it's those. Is there any way to center the steering wheel?? It's driving me crazy!
Old Feb 22, 2017 | 02:21 PM
Bluegrass 7's Avatar
Bluegrass 7
45 degrees is a lot.
Likely an arm is bent or the pitman arm has been moved.
Or the steering shaft coupler has been moves from the hit.
The steering wheel is locked when setting so the shaft coupler down under the master brake cylinder is the first place to check out.
Find the cause as it to serious to let go like that.
Good luck.
Old Feb 22, 2017 | 04:04 PM
Lovin193's Avatar
Lovin193
Thanks, I'll check it out. I also bought a pitman arm and idler arm but haven't got to replacing those yet.
Old Feb 22, 2017 | 04:49 PM
steve(ill)'s Avatar
steve(ill)
did you get alignment AFTER the hit ? The tie rod ends are adjustable to set alignment and ALIGN THE STEERING WHEEL... You point the steering wheel straight forward, then look at the tires.. They will be angled to one side.. loosen the tie rod ands and adjust one IN 4 turns and out OUT 4 turns... still in alignment, but the tires now are more in alignment with THE STEERING WHEEL... (you may need more than 4 turns, keep checking).......... this assumes nothing is BENT or failed.. Normally if BENT you will no longer be in alignment and have the correct toe in.
Old Mar 3, 2017 | 11:42 AM
Lovin193's Avatar
Lovin193
Update
I replaced the ball joints and pitman arm then got an alignment. Everything is back to normal. Thanks
caminokid863
1997 - 2003 F150
May 9, 2015 09:09 AM
AZ48
Jan 30, 2014 11:24 PM
cbzdel
Jun 20, 2012 10:24 PM
stumprider69
1997 - 2003 F150
Mar 12, 2012 10:05 PM
Sharky146
Sep 6, 2010 09:13 AM
