351w rebuild
Old Jun 12, 2018 | 02:28 PM
Conanski's Avatar
Conanski
Originally Posted by Stangman70
Paul when you posted the HP and TQ numbers were those for the AFR heads?
Yes they were.
Can you recommend a desktop dyno that is free to use?
Can't say I have ever seen it available for free, if you want some other combos run I'll do that and I can also post up graphs too if you like.
Old Jun 15, 2018 | 09:43 PM
Stangman70's Avatar
Stangman70
So my 3500 budget does not seem to be a reasonable expectation for parts l am listing out. Therefore my build plan will change.
As stated in another thread, I want to just refeshen up the engine a little but invest in a solid top end. Truck won't be a looker, just a good city driver and occasional hauler of stuff in the eventual move we will be doing.
I keep seeing very affordable aluminum gt40 heads on eBay out of California. They are newly machined with 1/2 inch holes ready to go but if it looks too good to be true it probably is
Old Jun 15, 2018 | 09:53 PM
Skip1970's Avatar
Skip1970
is there a reason you prefer this motor over a 460?
Old Jun 15, 2018 | 11:03 PM
Stangman70's Avatar
Stangman70
Skip the 351 I have is a roller block. I wanted to go with it for that reason as well as availability of parts. Economy, price, and easy swap also played factors.
I've never messed around with a big block which would be cool.
Old Jun 17, 2018 | 04:38 AM
Skip1970's Avatar
Skip1970
what years have the roller cam 351w? im not sure if mine were rollers or not when i did the heads.
Old Jun 17, 2018 | 08:38 AM
baddad457's Avatar
baddad457
94-97 F4TE blocks
Old Sep 4, 2018 | 11:46 PM
Stangman70's Avatar
Stangman70
Delete please
Stangman70's Avatar
Stangman70
Hey guys,
I found a listing for some D0OE heads for my 351. Better than my stock heads? Are there other stock heads worth looking into?
Old Sep 5, 2018 | 05:58 AM
baddad457's Avatar
baddad457
Not as good as GT40's but slightly better than E7's that haven't been ported
Old Jan 14, 2019 | 04:35 PM
Stangman70's Avatar
Stangman70
Hey guys,
Thought i would update everyone.
Block went off to the machine shop today! Sold some stuff and have a budget for AFR 185 heads now!
Just need to pick a cam now. I have some thoughts and now that the budget is back on I am looking for that 400 rwhp goal again.
Builder recommended that i look into link bar lifters instead of the spider and dog bones I have now due to some failures in other engines of the same type. Any thoughts on this?
Old Jan 14, 2019 | 09:26 PM
baddad457's Avatar
baddad457
Hey guys,
I've had dog bones and spyder in my 331 now for 14 years. These worked by a Ford Racing Z303 cam. Link bar lifters can and do fail too.
Old Jan 15, 2019 | 12:54 AM
Stangman70's Avatar
Stangman70
baddad I run the the stock lifters in my 5.0 for my mustang with an E303 with no issues. I have my eye on this cam but i dont think its outrageous as far as lift or duration goes. Your thoughts?
https://www.summitracing.com/parts/cca-35-425-8
Old Jan 15, 2019 | 10:08 AM
  #28
baddad457's Avatar
baddad457
Based on what you posted as parameters back when you started this thread, I would pick a cam with less duration and a wider LSA in the 112-114* range. I doubt that cam's going to let you pass emissions.
Old Jan 15, 2019 | 03:27 PM
  #29
Stangman70's Avatar
Stangman70
I did some searching and ran across this cam
https://www.summitracing.com/parts/cca-35-420-8
Old Jan 15, 2019 | 07:14 PM
  #30
baddad457's Avatar
baddad457
Passing emissions is going to be your limiting factor here. That 110* LSA I doubt will get you past that. You're going with a carb, right ? What intake and carb ? Seems to me an EFI cam will be what you're going to need. They work great with carbs too, so don't let the EFI label think they don't. I've run them and they actually make a carb more responsive and idle cleaner.
