Back up cameras
Old Jun 10, 2018 | 08:46 PM
LTSnyder's Avatar
LTSnyder
Back up cameras
I have a question I'm hoping someone can help with. I have the camera in the tailgate, and another by the 3rd brake light. When I take the tailgate off, the camera by the 3rd brake light stops working. Is there a way to keep that camera operational when the tailgate is off?
Thanks for your input.
Old Jun 10, 2018 | 09:41 PM
saskowner's Avatar
saskowner
Did you put the sealed pugs from your glove box in the empty plugs where the tailgate wiring attached? I think they need to be in to make the 3rd brake light camera work.
Gary
Old Jun 10, 2018 | 09:47 PM
chipssuperduty's Avatar
chipssuperduty
Hello,
Look in your console or glovebox and you should have a few plug connector caps in a plastic wrap. When you take your gate off, cap the wires under the truck that you unplugged. Not sure if you have to look anywhere else on your screen for just that high mount camera. I do not have that setup but I read a little about it somewhere.
I figure it is something simple since some take their gate off for the 5th wheel hookup and I would think the high mount camera is still active for that purpose.
Update when you figure it out. Hope I am sending you in the right direction.
Old Jun 11, 2018 | 05:52 AM
LTSnyder's Avatar
LTSnyder
Thanks for responding. Yes, I put the plugs in the wire harness. There are three plugs in the kit. I could only find the two places to put the plugs that you have to disconnect to remove the tailgate. The third plug is a small round one and I couldn't find anywhere for it to go.
Old Jun 11, 2018 | 08:54 AM
dksmith17's Avatar
dksmith17
Are you referring to the CHMSL camera?
I removed my tailgate on my 18 and CHMSL still works and I didn't mess with the plugs at all. I do have the factory 5th wheel and goose package.
Old Jun 11, 2018 | 11:58 AM
RZAR's Avatar
RZAR
Same problem here. Tailgate off CHMSL camera works sometimes if I hit the button. I don't understand why Ford did not make it defualt to the CHMSL camera when the tailgate is removed.
Old Jun 11, 2018 | 12:04 PM
nuctrooper's Avatar
nuctrooper
About the size of a pen cap? That's for the rear camera on trucks equipped with the 360 degree camera system.
Old Jun 11, 2018 | 06:19 PM
LTSnyder's Avatar
LTSnyder
Yeah, I have the 5th wheel package too. Took the tailgate off, put the caps on the wires, pushed the button on the dash for the camera and nothing. Was just hoping there was a trick someone knew of.
Ford Fx4
Oct 29, 2018 07:05 PM
Scott G. Treffert
Nov 13, 2017 10:57 AM
ljlund
Jun 20, 2017 09:33 PM
Americal_Vet
Mar 23, 2017 03:18 PM
geoloser
Jun 12, 2001 04:35 PM
