460 Smokes only sometimes
Old Jun 22, 2018 | 03:45 PM
1994Toyota's Avatar
1994Toyota
Yes, a few inches down, almost cant see, and there is nothing in the overflow bottle
Old Jun 22, 2018 | 05:10 PM
Franklin2's Avatar
Franklin2
Are you filling the radiator up to the vary top? Drive it for a day and check next morning and it is low?
How low was the level? Really low / cant see it or just a few inches down from the opening?
If just a few inches down that is normal for the cooling system. When it heats up the coolant expands and goes to the over flow tank.
Once it cools if radiator is really low it will pull coolant back in from the over flow.
Dave ----
If he fills the radiator to the very top, and then fills the overflow bottle half-way, the radiator should stay completely full. But I know with these old trucks you can't pre-fill the overflow without rigging the top of the tank. But that is what I do, the last one I pulled the plug out of the tank and use a little funnel to fill it.
herdfan75
17
Sep 28, 2017 09:32 AM
jasindude1
Apr 16, 2016 04:24 AM
matpasch
Aug 27, 2009 01:03 PM
reamer
Apr 5, 2005 02:49 PM
cruser
Oil & Lubrication
Nov 14, 2003 06:57 PM
