tranny whine
Old Jun 10, 2018 | 08:21 AM
baitmaster's Avatar
baitmaster
tranny whine
Installed new trans pan with oil drain plug. Dumped oil, put new pan on, drove in for a week. Dumped oil again, and also added a trans additive. I now have a real slight whine noise when I go from a dead stop. Don't hear it on the road. Is this something I should be concerned with?
Old Jun 10, 2018 | 10:48 AM
alloro's Avatar
alloro
What did you use for fluid and did you change the filter?
Old Jun 12, 2018 | 06:58 AM
baitmaster's Avatar
baitmaster
Changed filter, and used the recommended Motorcraft juice, and along with the tube of trans additive. There was very little crud around the magnet on old pan, just some black film, no metal.
Old Jun 16, 2018 | 10:00 AM
alloro's Avatar
alloro
That still doesn't tell us what you used. You wouldn't be the first to use what they thought was the correct fluid only to find out it wasn't.
Old Aug 14, 2018 | 01:21 PM
baitmaster's Avatar
baitmaster
Mercon V is what I put in it.
Old Aug 14, 2018 | 01:36 PM
ford390gashog's Avatar
ford390gashog
The whine is from the torque converter. What did you add? The only additive you should add is lubegard red. Anything else and you are up a creek. The mercon V is already highly fortified and you may have slippage.
Old Aug 16, 2018 | 12:23 PM
baitmaster's Avatar
baitmaster
A 10oz bottle of LubeGuard Red is what I added, in addition to the Mercon V. Have since drained 5 qts out and added more new, so it should be pretty clean. I've been pulling my boat, and haven't noticed anything unusual, except for the slight whine. Don't hear it at highway speeds. Shifting up and down is doing what it is supposed to. Guess I'll run it til it dies?
L-ight
20
May 21, 2018 03:49 PM
emspjay
Dec 10, 2014 06:14 AM
Domino
Mar 18, 2006 07:00 AM
ThatGuy Dan
Jul 24, 2005 03:51 PM
onocifor
Feb 15, 2004 02:12 PM
