1978 - 1996 Big Bronco
Bronco 4x4?
Old Jun 9, 2018 | 02:11 PM
Amicus's Avatar
Amicus
Bronco 4x4?
thinking about getting a bronco but was wondering about 4x4 system. Is it a limited slip or true lockers. I have a 99 super duty and it has a limited slip that sucks. I plan on using it for hunting.
Thanks
Old Jun 9, 2018 | 04:32 PM
AbandonedBronco's Avatar
AbandonedBronco
Hi Amicus,
Every Bronco automatically comes with four wheel drive (no 2WD Broncos). Some came with limited slip and the rest were open differentials. The limited slip was not a common option, so open diffs are easier to find.
You can tell by looking at the axle code on the door.
If it's a solid number, it's open diff. Like 19.
If it is preceded by a letter, it's limited slip. Like, H9.
True lockers would be aftermarket.
Old Jun 9, 2018 | 05:36 PM
Amicus's Avatar
Amicus
Originally Posted by AbandonedBronco
Hi Amicus,
Thanks. Open diffs. How does that work?
Old Jun 9, 2018 | 07:06 PM
AbandonedBronco
Like 99% of most vehicles out there. The power is transferred to the wheel with the least amount of traction (hence the reason for traction lock differentials). When both wheels have equal traction, they get equal power from the engine.
Old Jun 9, 2018 | 08:50 PM
McLeod's Avatar
McLeod
But you can always install lockers.
A selectable or an e- locker would give you the best of both worlds.
Old Jun 13, 2018 | 07:52 PM
00t444e's Avatar
00t444e
An open diff always puts equal torque to both wheels, however that torque is determined by the wheel that takes the least resistance to spin. For example say it takes 200 ft lb to move a vehicle but one wheel is on a slick surface that only requires 50 ft lb to spin that wheel, the other wheel that is on a hard surface will also be getting 50 ft lbs of torque but that isn't enough to move the vehicle so that wheel will just sit there while the other wheel spins. A limited slip works by using clutches or gears to transfer more torque to the wheel with greater traction, a locker locks both axles together regardless of the torque or traction on each wheel. Broncos never came from the factory with lockers, the rear is either open or limited slip and the front is open, although I believe a front limited slip was optional on few model years but it was rare.
Old Jun 14, 2018 | 01:15 PM
Amicus's Avatar
Amicus
Thanks, Gentleman
I hate seeing one tire spin and the other just limp. I'm looking for another hunting/ranch vehicle and can't make up my mind. I love my 7.3 and was thinking about getting another one but been looking at some broncos. Either way looks like I would have to install some lockers to get all wheels to spin.
Thanks again
Old Jun 14, 2018 | 01:29 PM
McLeod's Avatar
McLeod
Or a welder...
Old Jun 14, 2018 | 04:20 PM
Pandaz3's Avatar
Pandaz3
Trailering
I had a '81 300 6 4 spd OD manual and it had limited slip front and rear. I did not order it that way, I just bought it new from the Ford Dealer in Enterprise, Alabama. Had to go overseas and always regretted losing that one. A new '86 v8 auto XLT all gussied out, did have a limited slip rear but not front. I never warmed up to it.
Old Jul 7, 2018 | 10:25 PM
rory71's Avatar
rory71
There were 2wd factory Broncos made, sold down south mostly, like the 2wd Jeep grand cherokees & xj models. Just for a heads up!
Old Jul 8, 2018 | 10:57 AM
Pandaz3's Avatar
Pandaz3
Trailering
I have a 2009 2wd Escape now, the last 2wd of my life for new cars anyway.
Old Jul 8, 2018 | 11:15 AM
BigBlue 94's Avatar
BigBlue 94
where did you get this information? The ONLY 2wd Broncos were test mules used by ford.
when looking at the door jamb sticker, if there is a third digit in the axle slot, that signifies a limited slip front. Ex: h92 is limited slip 3.55 front and rear.
Old Jul 8, 2018 | 11:46 AM
AbandonedBronco
I was wondering about this too.
At least in the US, there was never a 2WD Bronco. I've heard some were made in Mexico, but they were a dealer option, and not done by Ford.
Old Jul 8, 2018 | 12:25 PM
mary-kate's Avatar
mary-kate
I came across a 2WD Bronco in Southern California. Almost bought it just because it was so weird. It was a '92, and bare bones with the rubber interior, six cylinder and 5-speed - only option was A/C. IIRC, the guy said it was an old city truck for the building inspector or something. Seen a few others for sale online over the years - always checked the pictures just to see if they're legit and not miss-listed.
I've never seen anything about 2WD in the factory literature, I'm guessing it was a delete option. Once the 5.0 became the standard Bronco engine you had to delete it to get the six, although I've never seen a factory six past '93. I've never seen a 5.8L Bronco with a factory 5-speed, but the automatic was almost a thousand dollar up-charge separate from the motor; I'm guessing you could get one if you were willing to wait, as I have seen an F150 with a 5.8L 5-speed Mazda combo built in '88.
I hope my sightings won't make any of the scholars lose their senses. Don't forget, Ford has made goofier stuff...like the 2WD Bronco II's that have a transfer case or the OBS F150s with the 3.8L Essex V6.
murph_murphy
Nov 27, 2010 08:29 PM
Gage2502
Mar 1, 2009 10:29 AM
coon1976
Nov 23, 2005 03:14 PM
BroncoMTR
Mar 31, 2003 01:23 AM
fors43
18
Jan 12, 2003 02:11 AM
