Starter issues
Old Jun 9, 2018 | 10:55 AM
Daxy's Avatar
Daxy
Starter issues
I have been having trouble locating the correct starter for my 95 f-150. The one the AutoZone keeps saying I need is not correct. The starter gears resting position is protruding about 1/2 in. further from the housing than it should be. I have a picture of the starter I pulled off the truck ,sitting next to the remanufactured be unit. Anybody else have this same issue? My truck has the 4.9l and a manual transmission btw.
Old Jun 9, 2018 | 11:30 AM
BLDTruth's Avatar
BLDTruth
Looks like they gave you a starter for an auto tranny. They are different. I'd take your old one in and compare it to the new one you buy this time.
In the future I would recommend avoiding the zone like the plague - this type of crap happens all the time with them, in my experience.
Old Jun 9, 2018 | 12:15 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Not a great picture, but the manual transmission starter is the newer one in the foreground. A/T model in the background.
Note these are the older series wound starters as opposed to the PMGR type.
Old Jun 9, 2018 | 01:02 PM
krooser's Avatar
krooser
BLD is correct...
Old Jun 9, 2018 | 02:29 PM
1TonBasecamp's Avatar
1TonBasecamp
Sounds like what you're running into is their database is using the "Mustang-factor" because somehow for the Mustangs (and maybe other vehicles as well) for the '79 and later model years they somehow managed to use just one part number for all transmission types. In the case of the later PMGR starter style like you have on your truck, that would have equated to a #3205 (semi-standard industry number) for automatic transmissions.
Whereas our trucks continued to use two different starters based on the transmission type. As said then, for trucks the #3205 is for Auto Transmissions only.
So when you take it back ask them to pull up a #3223 to look at as well so you can compare the two, to what you pulled from yours.
The #3223 is officially for the manual transmission trucks.
Good luck!
Paul
rkik
31
Sep 3, 2017 10:11 PM
Spktyr
55
Dec 28, 2016 08:56 AM
PStruwing
Apr 9, 2012 10:59 AM
joe f350
Nov 15, 2010 10:05 AM
subford
Electrical Systems/Wiring
Sep 13, 2005 09:29 PM
