AC is not very cold
Old Jun 8, 2018 | 02:00 PM
boybowser's Avatar
boybowser
AC is not very cold
1997 F250HD AC is not blowing very cold, the system is charged, the compressor is kicking in and out as expected, AC Max does not bring seem to be working, is there a diagram to explain the venting functions. Had trouble this winter with heater door not opening or closing properly, inside of truck at heater ducts always blew cold air, I got in and messed with it then no problem with heat, and suspect this may still be a problem may it is not operating properly yet. Can anyone explain how the inside duct work and controls operate?
Old Jun 8, 2018 | 02:30 PM
subford's Avatar
subford
Is this what you are looking for?
Old Jun 8, 2018 | 02:54 PM
boybowser's Avatar
boybowser
Thanks very useful, found the max AC issue, was a vacuum connection behind pass kick panel, is there a procedure for adjusting the blend door I finagled it with a screw driver and the AC vents are definitely blowing colder air, but when I move the vent control between hot and cold it is very sloppy.
Kemicalburns
Dec 14, 2018 07:11 PM
CJ Morin
Dec 26, 2015 12:14 AM
scottskingdom
Dec 2, 2011 04:25 AM
hlwinesett
Jul 17, 2003 07:59 PM
MRB068
May 13, 2002 06:57 AM
