Sponsored by: Auxito
Engine swap 2003 into 1998
Old Jun 8, 2018 | 08:58 AM
Woody Smith's Avatar
Woody Smith
How hard is it and what will need changed to swap a 2003 5.4 into a 1998 F150 that has a blown 5.4 ? Newer engine is complete fan to flywheel. And will I need to do anything with ECM ?
Old Jun 8, 2018 | 09:18 AM
jughead808's Avatar
jughead808
Should be a direct swap. Use all the stuff that came off the old motor; ie the coil packs and wires. You’ll have to get the ECM tuned as the old motor is a non-pi and the new one is pi.
Old Jun 8, 2018 | 09:21 AM
Woody Smith
ECM
What if I can get the ECM with the donor engine? Will it plug into the 98 harness and which sensors if any should I be worried about swapping as well ?
Old Jun 8, 2018 | 09:38 AM
jughead808's Avatar
jughead808
Get the harness also. Your harness won’t support the cops. Also the the newer truck probably has PATS and I don’t think yours does, that will be a whole other can of worms. It’s just easier to have a tuner adjust your ECM.
Old Jun 8, 2018 | 09:40 AM
jughead808's Avatar
jughead808
All of the sensors off the old motor should go onto the new motor, as all of the 5.4’s are Windsor
amr5080
22
Jun 22, 2025 12:30 PM
galaxie460
Modular V8 (4.6L, 5.4L)
Jun 30, 2014 03:03 PM
F0rdFre@K
1997 - 2003 F150
29
Dec 20, 2008 08:19 PM
JohnnyTapia
1997 - 2003 F150
Aug 13, 2004 09:29 AM
