Sponsored by: Auxito
pi intake
Old Jun 7, 2018 | 08:45 PM
evocross's Avatar
evocross
pi intake
hey guys ..... im new to the forums ! my reason for being here is because i just picked up a 98 f150 4.0l
i want to put a pi intake on my 4.6 and would like to know if anyone has had this exsperience
and if its possible to put the pi intake on the 4.6 f150 version of the 4.6 . please enlighten me with what
you know ? thanks
Old Jun 8, 2018 | 09:04 AM
jughead808's Avatar
jughead808
Short answer is no. Your engine is a non-pi and the ports are different and will not match up.
Old Jun 8, 2018 | 09:47 AM
jughead808's Avatar
jughead808
If you have the pi intake, can you get the pi heads? If so you will boost the power output of the motor. The pi heads will increase the compression ratio by a full point. Also if you do swap the heads take the coolant tube from under the pi manifold as it is longer and sets deeper in the valley and will clear the pi manifold. You may have to extend some wiring for the temp sensor. Also don’t reuse the head bolts as they are torque to yeild and can’t be reused.
Old Jun 8, 2018 | 10:11 AM
jughead808's Avatar
jughead808
Almost forgot to mention, if you have a Romeo engine use the Romeo heads if a Windsor use the Windsor heads.
Old Jun 8, 2018 | 08:31 PM
evocross's Avatar
evocross
thanks jughead808 !! that information helps alot ...... so what about a tune ? is that engine tunable?
Old Jun 9, 2018 | 05:05 AM
jughead808's Avatar
jughead808
Yes, you can get tunes for it. They will have to be custom tunes from a reputable tuner. 5Star comes to mind, Troyer was another but I think he is no longer in business. I am sure there are other but I see 5Star’s name mentioned on a couple other forums that i am on.. 5 Star News - 5 Star Tuning
Shovelhead 93
1997 - 2003 F150
Jul 27, 2015 06:05 PM
500TPmech
1997 - 2003 F150
Jan 1, 2012 09:28 PM
OldBlue68
Oct 2, 2008 03:38 PM
zman764
Modular V8 (4.6L, 5.4L)
Jun 3, 2006 10:00 PM
trenth
1997 - 2003 F150
Apr 10, 2006 08:35 AM
