Curious about how you set your Torklift fast guns
Old 06-07-2018, 04:41 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
I know Torklift recomments using that rubber washer to set the tension on their fast guns, but doing that there is not the remotest possibility doing what they recommends sets the tension evenly. I have one that must take at least twice as much pressure as the others to close and I have also noticed that dealers do not use the rubber washer to set the tension nor do a lot of other folks. The key for my is to set them snug, but not so tight it feels like it will rip the eyelet out of the camper. What do you do?
Old 06-07-2018, 06:15 PM
_hedge_'s Avatar
_hedge_
_hedge_ is offline
Hope I can explain this. I set mine so that when I close them I see half of the lock hole covered as it starts to tension... and then snap them home. I've heard others that do it the same way is where I got it from.
Old 06-07-2018, 06:19 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
I pretty much do the same thing. Does anyone bother with the rubber washer on the fast gun? It really doesn't take much to keep our truck camper in place. It doesn't seem to move around at all on the road. We normally check ours when we take on fuel.
Old 06-08-2018, 10:16 AM
Rustofer's Avatar
Rustofer
Rustofer is offline
When we bought ours (we were new to truck campers) the dealer told us the rubber washer was to keep dirt out of the mechanism. When we got home, I looked up Torklift's procedures and read about the washer being used to set the tension, and so I followed that for a few times. Now I go by half-the-lock-hole (also mentioned in the Torklift manual), which results in the same "feel" as when using the rubber washer.
Old 06-08-2018, 01:28 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
I have one that if I were to use the rubber washer, I think I would just about rip the hook out of my camper. So far I haven't met anyone on the road who uses the rubber washer and was curious if anyone did. I mostly go by feel. I tend towards making sure they are not too tight as I want to spring in the fast gun to have room to work. You would be surprised how many campers I saw when we were searching for a Northstar to buy that had at least one eyelet that had pulled out, I suspect from too much pressure on the turnbuckles.
Old 06-08-2018, 05:22 PM
River Wild's Avatar
River Wild
River Wild is offline
Doesn't really apply but I have the Derringers and there is no rubber stopper. I just make them "snug". With a thick rubber mat I've never had an issue..
Old 06-09-2018, 08:07 PM
914fan's Avatar
914fan
914fan is offline
What about the standard turnbuckles or the hijack round one's .Do you just make them hand tight? Ive read you need to get them to 300 ft pounds but have absolutely no clue how you could possibly torque them to any spec
Old 06-09-2018, 08:17 PM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
I've heard that number too, but give it no credence. TCs are all different weights and pose different challenges. I snug my Fast Guns down and have gone thousands of miles without a problem. I agree there is no real way to measure the actual torque or any way to keep it constant while traveling.
Old 06-12-2018, 04:53 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Alaskan_Warbird is offline
Can you better explain this "half of the lock hole covered as it starts to tension" thing? How much tension should I feel as the lock hole starts to become covered?
Old 06-12-2018, 06:37 PM
Rustofer's Avatar
Rustofer
Rustofer is offline
The point at which the lock hole is half covered by the handle is the point where the slack is taken up and the tension starts to build.
Old 06-13-2018, 11:12 AM
WyoBull's Avatar
WyoBull
WyoBull is offline
It really is a "feel" thing as to how much tension. Luckily, when we bought our camper the dealer was really good and showed me how they should be set.
My guess is that most people over tighten them. It does not take a lot of tension but it is hard to explain what that feels like.
Kind of like answering the question, "What is sexual harrassment?". Hard to explain it but I know it when I see it!
Old 06-13-2018, 11:44 AM
Alaskan_Warbird
Yep - I've been setting mine way too tight then. Good to know. Glad I haven't damaged anything...
Old 06-15-2018, 02:18 PM
JT250's Avatar
JT250
JT250 is offline
I use it as a reference but definitely do not use it as a "rule" I am a couple turns past that on mine. My camper likes to move. The center of gravity is behind the rear axle. I called Bigfoot about it and they said yes, all of our short bed campers COG is behind the axle. I love everything about the camper besides this. I will see if how I have mine set goes along with the "half-hole rule"
Old 06-18-2018, 12:52 PM
greendragon.'s Avatar
greendragon.
greendragon. is offline
I also go by the half hole rule, do not over tighten it causes damage to the TC connect points.
ford2go
Garage & Workshop
24
05-02-2009 11:51 PM
46069dord
Paint & Bodywork
03-21-2008 09:55 PM
eco
Garage & Workshop
13
05-15-2007 05:51 AM
mzimmers
Garage & Workshop
04-06-2006 06:25 AM
fordborn
Kansas Chapter
10-31-2005 09:28 AM
Quick Reply: Curious about how you set your Torklift fast guns
