Spare tire access lock seized
Old Jun 7, 2018 | 03:21 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
I wanted to do my annual dropping of the spare to check the pressure and grease the cable but the lock to the rod insert area in the bumper was seized tight. Took over an hour to get it unstuck with releasing agent spray on both sides. Anyone else had this happen and is there preventive maintenance required? On this, and all previous trucks for years, I always squirted a little WD40 on the mechanism before reinstalling and never had any issues but this one seized up completely. I noticed there are two rubbery gaskets on the front and back of the turning mechanism and am guessing that dirt and grit went in between and hardened right up.
So now that it is all cleaned up, shall I leave it dry or spray lube it again for next time? Thought I was doing myself a favor lubing it up last year but it backfired!
(and the spare pressure was way down, so better check yours guys)
Old Jun 7, 2018 | 03:54 PM
GlueGuy's Avatar
GlueGuy
Was the lock mechanism seized (unable to turn), or was the dirt around the housing preventing you from pulling it out?
I just tried mine, and the lock turned OK, but it was a small challenge to pull the plug.
If it was just the lock, I might drop a little graphite-based anti-seize into the lock.
Old Jun 7, 2018 | 04:39 PM
CR172's Avatar
CR172
STOP using WD-40. It is NOT a lubricant. The only thing WD-40 should be used on is cabinet hinges and as a stainless steel cleaner. That stuff causes more harm than good.
Old Jun 7, 2018 | 05:59 PM
JKBrad's Avatar
JKBrad
Couldn't agree more. WD40 is for penetrating and water displacement. It degrades quickly as lube. It will clean away any meaningful lube that was already there and dry up. If you were using WD30 on your door hinges, that might part of the reason they were squeaking.
Old Jun 7, 2018 | 07:41 PM
Big-Red-Lariat
been using KROWN rustproofing spray on the hinges, same product as for rustproofing the underbody.
Old Jun 7, 2018 | 08:33 PM
JKBrad's Avatar
JKBrad
I would use a white lithium spray lube on both the hinges and spare tire winch. Use it on your door latches and hood hinges too. If you look at you tailgate higes you'll see that Ford uses the white lithium there too. It doesn't evaporate and maintains a high film strength over a long period of time. Spray it on the latches too. I don't know about rust proof coating s or KROWN, since I don't have to worry about rust down here, but if it isn't made to lubricate then that could be a problem.
Old Jun 7, 2018 | 09:16 PM
ecoboost12's Avatar
ecoboost12
The only thing WD-40 is good for is a gasoline flooded engine,Spray it in the air intake or throttle body or
directly into the throat of a N/A engine.
Old Jun 7, 2018 | 09:46 PM
jimmy-six's Avatar
jimmy-six
Aero-Kroil is my favorite. at one time not available to the public, you had to steal it from your employer. now available most everywhere..Orange can
Old Jun 9, 2018 | 09:46 AM
Aftrmidnite's Avatar
Aftrmidnite
Don't use Graphite on any modern lock, it gums them up. Use Spray Heavy Silicon Lube.
Old Jun 9, 2018 | 10:23 PM
TJReams's Avatar
TJReams
Yep use only dry silicone spray on any lock. Use the heqvy silicone on hinges and areas that need or have movement. WD-40 contains parrifin and will attract dirt and dust and gum up everything.
Old Jun 9, 2018 | 10:44 PM
brokenleg's Avatar
brokenleg
I keep my lock inside the console. It got a little rusty and hard to turn. So I lubed it with graphite. And I only use it when Im out of town with the truck. At home I dont worry about the spare.
Old Jun 12, 2018 | 09:14 AM
function12's Avatar
function12
It depends on the lock. Household lock like kwikset use a wet lube. Schlage uses a dry graphite lube. Use the wrong one one either one and it will gum it up. Throw the WD40 away. LPS 1 is a great thin wet lube. LPS 3 it a much thicker wet lube.
Old Jun 12, 2018 | 06:54 PM
GlueGuy's Avatar
GlueGuy
Standard anti-seize is dry graphite in an evaporating carrier. The liquid will let it get in there, but once it evaporates, all that's left is the dry graphite. It's kind of messy going in, but once it's dry, it will not attract dirt. I've used it on all sorts of locks that have to live outdoors.
AK-AlumADuty
Jan 7, 2023 09:53 AM
Big-Red-Lariat
2015 - 2020 F150
Nov 9, 2018 06:10 PM
tayous1
2004 - 2008 F150
Jan 31, 2011 03:46 PM
Medic911
2004 - 2008 F150
Mar 22, 2008 11:06 PM
msgtg
West Virginia Chapter
Aug 13, 2007 08:11 PM
