More power, minimum mods
Old Jun 7, 2018 | 01:09 PM
rogersdan's Avatar
rogersdan
Hello,
I have a 1988 F250 with 351w - currently stock. From the research that I have done - mostly on this site - I gather that I can get power improvements with a Crane 444232 cam and some exhaust modifications. I don't want to do any more than the minimum and want the truck to behave - no surging idle, etc. Question, will I need new springs with this cam? How much of the exhaust should I replace. Thanks for all the good info on this site! DR
Old Jun 7, 2018 | 01:15 PM
Tedster9's Avatar
Tedster9
Valve springs are an often overlooked part of engine maintenance or rebuilding. They work hard. Weak springs, or worn out springs, act like a natural rev limiter. The engine will spool up no higher than the weakest valve spring out of 16, basically.
Check with the camshaft manufacturer for their spring or spring pressure recommendation. Take the time to measure each valve springs pressure and the "installed height" and then shim as required. An inexpensive digital scale and a drill press will work for this in lieu of a dedicated $$$ valve spring tester.
May not need fancy springs for your application, but you might need fresh new ones after all this time. I wouldn't install old springs on a new camshaft, they aren't very expensive as far as that goes either. Getting them all within spec and consistent across every cylinder is one of those "attention to detail" things that makes for a smooooth running engine, better cold starts etc.
RadioControlGuy85
Feb 25, 2014 08:41 PM
whistle1516
Nov 15, 2010 09:44 AM
wilevel2
Jan 13, 2007 04:30 AM
Redmanbob
Sep 17, 2006 10:29 PM
jwtaylor
Jan 13, 2004 09:27 AM
