transfer case fluid
Old Jun 5, 2018 | 06:27 PM
bc75's Avatar
bc75
transfer case fluid
I have a 99 navigator i have read not to use mercon V in the transfer case. I seen ford says to use XL-12 transfer case fluid but on the bottle it says not to use in an AWD vehicle. Any ideas on what i can use.
Old Jun 6, 2018 | 09:15 AM
rla2005's Avatar
rla2005
My Ford Service CD states you are supposed to use Mercon in the transfer case. Mercon V is the replacement for the older Mercon XT-2-QDX. Why are you concerned about using the Ford approved replacement fluid?
Old Jun 6, 2018 | 12:57 PM
alwaysfords41's Avatar
alwaysfords41
The newer Ford guidance says use the XL-12 not the Mercon V. It is not indicated for vehicles with transaxles.
Old Jun 6, 2018 | 06:30 PM
bc75's Avatar
bc75
I had heard that the mercon V was breaking the transfer cases. And to use the XL-12 but the bottle says not for AWD so I'm confused. What to use.My vehicle only has 64,000 miles on it so i want to keep all the fluids changed since i tow a camper with it.
Old Jun 6, 2018 | 10:09 PM
alwaysfords41
It says not for AWD vehicles with transaxles.
Old Jun 7, 2018 | 06:23 AM
projectSHO89's Avatar
projectSHO89
Don't make this harder than it needs to be.
You can still buy fluid that meets the old Mercon/Dex III specification including at Walmart. If you don;t want to spring for the XL-12, use a fluid that meets the original specification.
Old Jun 7, 2018 | 07:29 AM
rla2005's Avatar
rla2005
I stand corrected. Good to know.
Batgeek
Jun 13, 2019 11:06 PM
mike L
29
May 29, 2019 08:50 PM
Dads79
2015 - 2020 F150
Feb 26, 2019 08:50 AM
parcours
Dec 22, 2016 10:03 AM
whitetmw
37
Jan 31, 2015 01:28 AM
