Brake light
Old Jun 5, 2018 | 12:29 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question Brake light
Recently the brake ligth is ON more time than usually at the start. I checked the level brake fluid an its OK, the switch in the parking brake seems it is working fine. What its the problem?
Thanks in advance
Old Jun 6, 2018 | 11:25 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
BUMP BUMP.
BTW the issue is more in the first start in the morning.
Old Jun 6, 2018 | 01:56 PM
farmert's Avatar
farmert
How is the vacuum pump? I believe the light will come on if there is low vacuum.
Old Jun 7, 2018 | 10:07 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Well till I can say its working fine, the pedal brake works fine no excessive pedal effort, the heater-air controls also work fine; there are not any visible leak or noise at the VP. Is there any easy way to check the VP?
Thanks for the input.
Old Jun 7, 2018 | 10:19 AM
farmert's Avatar
farmert
Check the vacuum at the brake booster hose with a vacuum gauge. You should see at least 19 inches of vacuum.
Old Jun 7, 2018 | 10:29 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Ok, I will. thanks
redman84
Dec 24, 2021 11:59 PM
morson82
Jan 9, 2011 01:51 PM
cclc1021
Sep 7, 2009 12:11 PM
Pete in Maine
Aug 21, 2008 12:22 AM
jqp00002
Jul 27, 2005 05:57 PM
