Higher octane question from the noob section
Old Jun 4, 2018 | 09:16 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Yes, flat tappets and today's motor oil is a big problem. When most normal engines were center camshaft, flat tappet, pushrod engines, oil manufacturers put a lot of zinc in the oil. Don't ask me the science. I don't know of a vehicle made today that has flat tappets, or tappets at all. So, off the shelf oils don't have a lot zinc now. And you can wipe a camshaft quick without it. Luckily there are plenty of oils and additives for our old caveman vehicles. I run Lucas Hotrod. Odds are if you pulled your camshaft, you'd find rounded lobes and concave lifters. Hell, I just replaced mine and it wasn't a year old. It had one lobe and lifter already showing signs, but I attribute that to just a being a crappy camshaft. When my old 351M failed, I autopsied it. Every lobe was rounded, every lifter concave. It wasn't drastic, but obviously I was getting a lot less valve lift than I should have.
Old Jun 4, 2018 | 09:50 PM
flatbedfordguy's Avatar
flatbedfordguy
X2 on everything ranger140892 said, Rotella15W40 still has high zinc content the last I read, 800ppm. You can always buy zinc additive or buy racing oil too.
Old Jun 5, 2018 | 05:12 AM
LiveFrom1977f150's Avatar
LiveFrom1977f150
i appreciate you bringing this to my attention. Im actually really glad i made this thread now. This is way more important than octane.... Over and over im fascinated with how far technology has come in vehicles.
Old Jun 5, 2018 | 11:58 AM
ranger140892
Grumpy goat
You ain't kidding. As much as I hate working under the hood of my newer vehicles, they're more reliable than our old beasts were when new. Tolerances are much tighter, innovation better, because of computer assisted design, new casting processes, better metals & polymers, and CNC machining. Some new vehicles are now using 0 weight oil, and for unbelievable amount of miles because their bearing clearances are so tight. But when something goes wrong with my new Jeeps, trucks, ATV's, tractors, I'm limited on what I can do to fix them.
Don't knock (no pun) hydraulic flat tappet camshafts. Yeah they're dated, but they work very well and will last if you run the right oil and change it and filter often.
Old Jun 5, 2018 | 01:12 PM
niko20's Avatar
niko20
If you use "high mileage" oils they have additives for the older engines like ours
DIYiT
Aug 22, 2011 12:15 PM
hevy metal
Dec 26, 2007 08:10 PM
78bigunns
Jan 12, 2006 07:34 PM
Redone
Nov 7, 2003 02:16 PM
ftwfred
Feb 22, 2003 09:18 PM
