Tire Size
Old Jun 2, 2018 | 10:49 PM
Cougar54's Avatar
Cougar54
Tire Size
I am looking to purchase a set of tires for my 1950 F1 with stock suspension and 15x8 wheels. Does anyone know if I should be able to fit a set of LT235/75R15 tires without any issues? The tire diameter is 29.3". Any info would be appreciated since I will not be able to drive the truck to the tire store and would like to be confident the size I picked out will fit properly when I bring them home.
Old Jun 3, 2018 | 05:56 AM
Badmoonreizen's Avatar
Badmoonreizen
Doug:
I had the same issue with my coe. After measuring backspace and offset, I took a rim to my local Discount tire store (not far from you) and had them mount a used tire on my rim, with the written understanding (right in the sales slip) that I could return it if any fitment issues.
I returned the monster tire and got my money back. I am sure they will work with you if you are going to buy a new set of tires.
Regards, Mark,
Old Jun 3, 2018 | 11:16 AM
50phil's Avatar
50phil
4wd Low
Doug,
Just be sure they are not too big as mine rub the tie-rod when turning sharply. I'm looking at putting 14" on the fronts with narrower tires.
I also have "serve" bump steering which is whole other issue in itself. May have to change out my front suspension at some point soon.
Phil
Old Jun 3, 2018 | 11:43 AM
Cougar54's Avatar
Cougar54
Originally Posted by Badmoonreizen
Doug:
Regards, Mark,
Mark, thanks for the info, I just may try that!
Old Jun 3, 2018 | 11:46 AM
Cougar54's Avatar
Cougar54
Originally Posted by 50phil
Doug,
Phil
Well, I guess I'll try and get one of the size I want and will bring it home for a test. I'll check the clearance at full turn both ways and report back. Thanks for the tip.
Old Jun 3, 2018 | 12:06 PM
petemcl's Avatar
petemcl
I have a set of used wheels and tires that I took off an Explorer that I bought for the same reason. When you come over Wednesday you can look at them. 5 x 4 ½ or 5 x 5 ½ ?
Old Jun 3, 2018 | 12:34 PM
Cougar54's Avatar
Cougar54
Cool! They are 5 x 5 1/2. See you Wednesday.
jtruck618
Jul 26, 2015 05:17 PM
mikecrom83
May 24, 2013 01:21 PM
offroad17
Oct 22, 2008 03:48 PM
UNLOADIT
2004 - 2008 F150
Nov 17, 2004 01:25 PM
