1982 F150 electrical question
I've since moved and had to sell her
But I found a 1982 F150 with 302 engine and AOD with 73,000 original miles from the original owner
Anyways...been trying to sort out a random cut off issue. Problem first presented itself a couple days ago. Was warming it up before going to work. Engine suddenly died after about 3 minutes of running. Would not restart. Figured the duraspark ICM bit the dust so ran to Autozone and replaced it. Fired right up, took it down the street where it promptly died the same way. After a push back to the house I started scratching my head. Been reading on here about the pickup coil in the distributor. Couple of things pointing me in that direction:
- On the last drive it began giving a shudder which almost felt like transmission but could be the engine missing
- The tach has been intermittent at best and my understanding is the pickup coil is related to the tach
Bought plugs, wires and ignition coil but have not installed yet. Want to make sure I'm barking up the right tree. Any thoughts would be appreciated
Given the chance to spend your time and money, I'd suggest the pickup, too. Here's the puller I used on my '84 351W. You need a fairly small puller for the job and the Posi Lock 103 was perfect:
One more thought - What about the ignition coil? Could that be acting up? Would it affect the tach if it did misbehave? Not sure, but might be worth a gamble.
I had to replace the pickup in my 86 ranger. I knocked the roll pin out of the gear, and dummy me used a two jaw puller to pull the gear off, and I broke one of the teeth. I looked and looked, and everyone said they sold a new gear, but no one had it in stock and could not get it. So I ended up buying a rebuilt Cardone unit from the store, and installed it. Now I had new problems. Instead of running bad, it would keep cutting out and not want to start sometimes, and I was getting a memory code 14, which the book indicated could be a bad dist pickup. I knew the only thing different was the Cardone distributor, so I pulled it out.
This time I used a bearing separator and the press to get the gear off, no broken teeth this time. I pulled the Cardone dist apart and could not believe what I was seeing. Old crud and gummy grease, and a original pickup coil inside the dist. They had not even taken it apart when they "rebuilt" it. You would think for $70-$80 that I paid for it, the could have at least put a new pickup unit inside it. I cleaned it up, re-lubed it, and installed a brand new pickup unit inside it, and now all is well. No way was I going to take it back and get another "rebuilt" piece of junk, I went through it myself.
But I agree it seems like they don't even attempt to clean on remans they just replace what doesn't work to get it working don't care if its a heat related fail issue they just let that **** go.
As previously stated the next suspect is the pick up coil. Elec components can get fussy with age and the heat can cause intermittent connectivity issues..
The 3 step scenario of a failing DuraSpark ignition module:
1) Module overheats, engine dies. Module cools down, engine restarts almost at once.
2) Module overheats, engine dies. Module cools down, engine restarts in an hour...or so.
3) Sooner or later, usually sooner, the module overheats, BURNS OUT. Now the engine will not restart.
Taking the module to an auto parts store to be tested. Will test OK unless it has burned out.
1974/86: Module located on the left fender inner apron.
Engine heat, especially when radiating from the V8's red hot left exhaust manifold, is the mortal enemy of these modules.
When replacing, use some washers to space it further away from the apron. The more airflow, the better.
The stator aka magnetic pickup coil inside the dizzy can have the same symptoms as the module.
btw: The original 1970's modules were so unreliable, that Ford techs referred to DuraSpark as NEVER/Spark!
I'm debating buying a new distributor or replacing the pickup. I bought the pickup coil ($15). Do I have to remove the gear and sleeve at the bottom? Or can I remove the whole assembly and replace the pickup coil without having to remove the bottom? I think I remember reading somewhere on here about using a multimeter to test resistance in the pickup coil plug to determine if it is failing but can't find the info.
I'll gap the new plugs and install with new wires as well as the new ignition coil because I have them on hand. When I replaced the ICM I spaced it off the fender hoping for better airflow. Figured that's why they have cooling fins built in. I'm up in Palm Desert and it's 113 degrees today so will wait til night to do any work on the truck.
Old (original?) ICM. The plugs were a bit stuck together...
Here's a link, looks like you can use two screwdrivers and pry it off.
https://www.ford-trucks.com/forums/1...l-install.html
I'm debating buying a new distributor or replacing the pickup. I bought the pickup coil ($15). Do I have to remove the gear and sleeve at the bottom? Or can I remove the whole assembly and replace the pickup coil without having to remove the bottom? I think I remember reading somewhere on here about using a multimeter to test resistance in the pickup coil plug to determine if it is failing but can't find the info..
Ohmagibles for the stator.....between the PURPLE and ORANGE wires going to the 3 prong connector to the distributor. You want to read between 400 ohms and 800 ohms...clean/check/wiggle the wires, too.
Good deal....
Spark plugs gapped (were pre-gapped but a couple were off .005"), antiseized and installed.
Began to install the new plug wires and was a bit confused:
The big numbers corresponded with 400 CID motors and the small numbers closer to the coil wire were for the 302. So...aftermarket distributor cap I think. Existing plug wires were going to the right number on the distributor cap but I thought the firing order for the 302 is 1-5-4-2-6-3-7-8 with the distributor going counter clockwise? In order on this cap it is marked: 1-3-4-8-6-5-7-2
I connected all the new plug wires exactly as it was with the existing wires as I knew it ran when parked. The existing plug wires for cylinders 1 and 2 came apart before I even started to pull them off the plugs. Probably the source of most of the problem.
Started up immediately and running much smoother. Pulled the distributor cap and the reluctor does not look anything like what is pictured in the diagram posted above. Started to feel around the distributor for the connector so I could test the resistance on the purple and orange wires (thanks Filthy Beast). Could not find any wiring coming off of the distributor. No vacuum advance, no electrical. Found a sticker that says "Refer to service manual. Timing not adjustable" on the exterior of the distributor housing. The rest of the sticker had been rubbed off.
Couple of crappy photos (sorry, it's 2:00 AM):
I can get better photos in the morning. Just for kicks I took it around the block and drove it about 20 minutes. Best its ever run in the short time I've owned it, no throttle hesitation, no shudder. Seems to have much better throttle response. It didn't randomly die on me and I stopped, shut if off several times in parking lots to see how the restart was. Fired up immediately every time. Before it was crank it for several seconds to a minute before it fired up.
So...drive as is or try to figure out the distributor situation? I still have no tach. If there isn't any connectors coming off of the distributor how am I getting tach intermittently? It really is random when it begins to work and only works for a few minutes before the needle goes back to 0.
