Ignition Issue
Old Jun 1, 2018 | 03:38 PM
Island'r's Avatar
Island'r
Ignition Issue
So recently I went to start my truck and all I got was "Click". I turned it back to off and tried again and the truck started no problem. I shrugged it off figuring it was just me. I drove the truck on a few occasions and no issues at all. A few weeks later it would not start. No click, nothing - no chime dinging, no lights on the dash. I cycled the ignition from ACC to start and back again a few times and then suddenly it started.
My first thought was ignition actuator as I know these can be an issue... But then I realized that my radio was all screwed up (incorrect time etc as if the battery had been disconnected) and I am now suspicious that its the ignition switch itself. Anyone else experience this?
The switches are more reasonable than I expected. I can get a motorcraft one for about $40.
Old Jun 1, 2018 | 04:06 PM
subford's Avatar
subford
Sounds like dirty battery cable connections.
I do not think the Ignition switch would cause the radio problem.
Old Jun 2, 2018 | 10:56 AM
krooser's Avatar
krooser
Ditto to what subford said...
Old Jun 2, 2018 | 02:26 PM
Island'r's Avatar
Island'r
New battery last year, along with new terminals and they are spotless and tight.
Cycling the key made it work that's why I was suspect of the switch.
Old Jun 2, 2018 | 03:10 PM
subford's Avatar
subford
You said terminals and not cables.
It could be at the other end of the battery cables or the cable it self.
The ignition switch will not make the radio lose the time or no chime dinging or no lights on the dash.
Old Jun 4, 2018 | 01:42 AM
MFJ's Avatar
MFJ
Just because the battery is a year old doesn't mean it's any good. Get it tested.
Before I replaced my battery, on occasion I would have to go under the hood and shake it to get the truck to start. Must have been a bad internal connection.
gaffmedic
Apr 5, 2017 02:15 PM
katenorris07
Apr 29, 2016 01:53 PM
expedite mike
Mar 18, 2016 08:18 PM
gaffmedic
Aug 10, 2007 09:26 AM
Mrkoopa
1997 - 2003 F150
Jun 25, 2007 01:40 PM
