AC Blower resistors
Old Jun 1, 2018 | 08:22 AM
traveler1234's Avatar
traveler1234
Question AC Blower resistors
Can anyone tell me where I can find the blower resistor in my 74. When I use the
AC, and once cold, the blower shuts down (all speeds) along with the AC clutch.
If I turn the truck off for 5-10 minutes it all works again. I want to check if I have
a cold contact problem.
Old Jun 1, 2018 | 08:46 AM
5851a's Avatar
5851a
The resistor isn't like a circuit breaker. If it overheats it opens the circuit like a fuse and has to be replaced. Sounds like you are tripping a de ice sensor. I would check the fan switch to make sure it's not overheating and losing contact. Just my thoughts, don't have a diagram for that.
Old Jun 1, 2018 | 01:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by traveler1234
Can anyone tell me where I can find the blower resistor in my 74?
When I use the AC, and once cold, the blower shuts down (all speeds) along with the AC clutch.
Blower motor resistor with factory installed integral A/C shown as 19706 in pic (click on it twice to enlarge it):
Look at center lower of pic for 19B680 flexible duct, then look to its left.
D3TZ-19706-A .. Blower Motor Resistor-Use with factory installed integral A/C / Obsolete
1973/79 F100/350 & 1978/79 Bronco.
NOS PARTS LTD in Waxahachie TX has 4 = 972-937-2201.
Old Jun 1, 2018 | 05:17 PM
5851a's Avatar
5851a
Thanks ND, I see the deice switch 19618, looks like it might be in blower housing? Always thought it just shut down compressor and didn't affect blower, but not sure.
Texascowboy77
Feb 4, 2019 07:18 AM
lawdawg79
Jul 25, 2015 09:39 PM
Haydendh
Oct 4, 2014 01:20 PM
86ford
Nov 9, 2002 10:59 PM
