Blower motor issues
Old Feb 3, 2019 | 01:39 PM
Texascowboy77's Avatar
Texascowboy77
Blower motor issues
Ok y’all need some help. I have a 78 f150 4x4 that the blower motor ain’t working. I changed the resistor to no affect now thinking it’s the relay for the blower motor but I can’t find the damn thing. Any help would be greatly appreciated.
Old Feb 3, 2019 | 03:23 PM
ranger140892's Avatar
ranger140892
Grumpy goat
You have AC, or just heat? Mine is heat only. Just a 35 amp fuse. I had problems with mine and finally figured out the fuse socket had gotten sloppy loose. I've never really fixed it. It's kind of a Fonzy fix...Instead of hitting the juke box, I slam the clutch to the firewall and the blower starts working again. No Charge
Old Feb 3, 2019 | 03:52 PM
Texascowboy77
Mine has factory ac and as long as I’m moving it’ll blow thru the vents or defrost wherever I have it set. But the blower won’t blow at idle or any speed
Old Feb 3, 2019 | 09:00 PM
dlburch's Avatar
dlburch
there is no blower motor relay on your truck. as previously mentioned, make sure you have power making it through the fuse...then to the AC mode switch...once you move the ac lever from off, it should send 12 volts to the fan speed switch...from there, the power goes to the resistor....then on to the motor (with the exception of high, then the blower resistor is completely bypassed...
Old Feb 3, 2019 | 09:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Texascowboy77
Mine has factory A/C
THREE different types of A/C for 1973/79 F100/350 & 1978/79 Bronco: Factory installed A/C; Deluxe dealer installed A/C; Economy dealer installed A/C
Factory installed integral A/C is combined with the heater, the A/C controls are in the same panel as the heater controls.
HUGE evaporator case located at the right rear corner of the engine compartment.
Old Feb 4, 2019 | 07:18 AM
Texascowboy77
Mine is the factory installed with A/C and heater controls on the same panel above the radio
Grantmh6.4
Oct 11, 2018 07:37 PM
jtcdudeman
Sep 16, 2016 01:05 PM
Doug3524
Jul 18, 2012 09:55 PM
Mark~T
Jun 26, 2008 12:29 PM
