Trans and engine compatibility question.
Old Jun 1, 2018 | 12:58 AM
Off Grid's Avatar
Off Grid
I have an 89 7.3 n/a from an F350, 4x4, 5 speed and would like to consider putting it in an 88 F250 4x4 with trans code Z. The 88 had a big block gasser. The seller is taking only the motor for a 70s F series build, selling the rest.
? Will my 7.3 bolt up to this trans? Do I need a different bell housing but existing gear box will be ok?
thanks so much for the help.
Old Jun 1, 2018 | 08:37 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
the diesel trans is diesel specific bolt pattern , and will not bolt to the gas block.
you are going to have to find a trans for your specific engine, and the 351 and 460 also use different trans bolt patterns.
Old Jun 1, 2018 | 09:05 AM
Conanski's Avatar
Conanski
Trans code Z is also for the ZF but as stated it won't fit a diesel so you have to swap that too.
Old Jun 1, 2018 | 06:13 PM
Off Grid's Avatar
Off Grid
Thanks for the responses. Do you guys know if the gear box is the same and possibly bellhousing can be swapped. ?
Thanks for the help.
Old Jun 1, 2018 | 06:16 PM
85e150's Avatar
85e150
ZF transmissions have an integral bell. No swapping possible. Some here have talked about drilling these to fit, as they are not off by much. (diesel vs. 460 pattern) No first hand info on that.
66gpw
Apr 21, 2012 12:09 PM
cnacowboy
Jul 23, 2010 10:00 AM
f350idi
Apr 24, 2009 07:54 AM
fling
Oct 4, 2005 08:48 PM
T MAN 554
Sep 25, 2003 08:59 PM
